Issues with popping and accelerating after 2500rpm
alp247
I need some help if any can help out, thanks
So the car just started to act sluggish all of a sudden when I started it up. So here are the symptoms I am getting. When I start the car I notice the car starts rough. When it warms up it idles fine for the most part. I take it out for a drive and as soon as it gets to 2500 – 3000 rpm it starts to struggle and Starts to strain almost bog out. It will do this when I baby it or when I try to get on it. I notice the car seems to misfire a bit more than usual. I mean I would get a few crackles here and there when I slow down but it seems more than usual. I decided to change the spark plugs, cap and rotor. For a few drives it seemed fine but now the symptoms came back. Does this seem like my dizzy is going out? I just realized my car is not holding memory for the time on my clock a few times. I am not getting any error codes as i checked.
Car info:
1988 Chrysler Conquest SHP
Stock for the most part except hard pipes and lowered
clean the battery cables and fuse link block connectors ,,do a complete job not a half a88 one
there are maybe 40 or so reasons that can cause the problem you describe,, start by testing fuel system pressure on the road under boost,, do an inj leak test , check pressure reg diaphragm
we can talk till we're all blue in the face but if you want to fix your car,, these are things you need to do
