NEW Owner - NO BOOST
mark_hub
I bought my first Starion a few days ago and im totally excited!
Now, I bought the car from a man named Evan here in Fairfield CA., he had it for sale on this site too, 83 black starion. Owner since '84
At the time of purchase i realized the valve lash needed adjustment right away, but i decided to take it for a test drive anyway... NO BOOST!
Turbo does not spin at idle (Stock turbo, receipt proves rebuild - $775) But it does spin momentarily when cranked and first starts up. No Shaft play, compressor spinds freely when off. When at idle, boost guage reads around 12 i believe, and after adjusting valves properly (thank god it didnt sound like a diesel anymore!) i took it for a spin again and boost guage will NEVER exceed 0 PSI.
The previous owner claims that it may need Rings, but compression is good...
Also, waste gate actuator arm was not hooked up, but i used a paper clip as a carter pin to hook up the waste gate arm, this still didnt fix the issue...
Im just curious if anyone can point me in a direction?
I possibly thinkin the waste gate vacuum diaphragm may have a hole in it, but.... is the diagphragm metallic or metal?
Thank you.
-Hubble
By the way, call me or text me anytime
916-350-1818
UPDATE:
yesterday a friend and I disassembled the back side of the turbo (the plate that covers the waste gate) and now the car boosts to about 7 psi.. but will cut out at about 3400rpm... any ideas?
Edited by mark_hub
Are you relying soley on the in dash guage? If so you might want to take a cheapy pressure guage and t it into the vacuum lines at the throttle body.
The dash guage is fed its signal by a sensor on the fireall near the break master cylinder. If something is messed up there, it won't read boost even when the car is making it.
