Euro/JDM taillight mod
17 replies to this topic
#1 Austin88ESiR
Austin88ESiR
    No sir, I didn't like it.
  • 1,838 posts
  • Interests:Cars, Motorcycles, Musician (bass and keys)
Posted 01 October 2007 - 02:48 PM
Kudos to Josh (Red 88TSI) for posting how to rewire US lights to function as Aussie (but still keeping US lights):
http://www.starquestclub.com/forums/viewtopic.php?t=37443
But if you have the actual Euro/JDM lights with the separate amber turn signals, here is the procedure for those.
http://www.beyonddarwin.com/starion/JDMtail.html
Edited by Austin88ESiR, 30 July 2008 - 07:48 AM.
Christian Luis Palacio
Posted Image  Posted Image  Posted Image
#2 Lunacy
Lunacy
  • 826 posts
  • Interests:Cars
Posted 01 October 2007 - 03:44 PM
And if you want some JDM lights PM me  biggrin.gif  Sorry to post hijack
#3 BORIQUEST87TSI
BORIQUEST87TSI
  • 198 posts
Posted 29 July 2008 - 04:42 PM
hi..  have installed a set of  euro lights on mi quest and was able to make work everithing except the turn lights  ,hazards work ok,,  but no turn lights right or left they stay lit when you try them  wont flash ,,,  have follow the procedure of  the web site but no luck at that point,  does anibody? hve made the the mod and work 100%  ??? PLEASE NEED HELP on this.. (turn lights were working 100% before the mod) also replaced the flasher unit with a heavy duty electronic one..
Edited by BORIQUEST87TSI, 29 July 2008 - 04:44 PM.
#4 Austin88ESiR
Austin88ESiR
  • 1,838 posts
Posted 30 July 2008 - 07:36 AM
QUOTE (BORIQUEST87TSI @ Jul 29 2008, 04:42 PM) <{POST_SNAPBACK}>
The info I have posted on my site works.  Double check the wiring and also remember to cut the wire from the hazards at the switch.
Edit:  Which procedure are you following? Josh's only works for domestic tail lights which has all red lenses.  My procedure is for the tail lights with the separate amber turn signals.  The two procedures are not interchangeable due to the differences in the pinouts of the wiring harnesses.
Edited by Austin88ESiR, 30 July 2008 - 07:47 AM.
#5 BORIQUEST87TSI
BORIQUEST87TSI
  • 198 posts
Posted 30 July 2008 - 12:09 PM
QUOTE (Austin88ESiR @ Jul 30 2008, 09:36 AM) <{POST_SNAPBACK}>
hi austin ,, yes its for the euro amber corners ones, and yes have cut it the wire on hazard switch you specified on the tutorial,,  everithing works running lights brake lights etc..  hazards ok  but no turn lights?   can you drop me ani ideas on this?  when you activate the turn ligths theylight up but dont flash..   so all the remaining functions works so it could still be wiring? any chance that you can make me one of those harness? il gladly will pay for it  , i was searching for a set of these for long time and want them to function properly.... let me know thanks.
#6 D_Venable
D_Venable
  • 6,588 posts
Posted 30 July 2008 - 01:05 PM
Sounds like a flasher unit problem. Did you get the EL-12 flasher, that's the one most of us who have put in a new one have gone to? Might have just got a defective one, hopefully.
2011 Silverado
88 TSI parts car
#7 BORIQUEST87TSI
BORIQUEST87TSI
  • 198 posts
Posted 30 July 2008 - 06:08 PM
QUOTE (D_Venable @ Jul 30 2008, 03:05 PM) <{POST_SNAPBACK}>
have tried both flashers the stock one  and the new one but same results  ,  turn lights were working before the the swap..
#8 D_Venable
D_Venable
  • 6,588 posts
Posted 31 July 2008 - 12:47 AM
QUOTE (BORIQUEST87TSI @ Jul 30 2008, 07:08 PM) <{POST_SNAPBACK}>
Well, the stock one is load based, and it normally runs 2 bulbs, so if you only have one hooked to it, then that'll probably cause it to stay on constant, especially if you've put LED bulbs in.
Which Electronic flasher did you get?
2011 Silverado
88 TSI parts car
#9 shift1313
shift1313
  • 6,860 posts
Posted 04 September 2008 - 06:47 PM
did you happen to blow out a front bulb?
Matt
84StarionES
#10 BORIQUEST87TSI
BORIQUEST87TSI
  • 198 posts
Posted 04 September 2008 - 07:23 PM
QUOTE (D_Venable @ Jul 31 2008, 01:47 AM) <{POST_SNAPBACK}>
got EL-12 FLASHER
#11 BORIQUEST87TSI
BORIQUEST87TSI
  • 198 posts
Posted 04 September 2008 - 07:24 PM
QUOTE (shift1313 @ Sep 4 2008, 07:47 PM) <{POST_SNAPBACK}>
ALL the bulbs are ok... checked ..
still no luck on this.....
Edited by BORIQUEST87TSI, 04 September 2008 - 07:26 PM.
#12 jd_stazza_brendan
jd_stazza_brendan
    Resident Australian
  • 458 posts
  • Interests:Starions
Posted 04 September 2008 - 09:57 PM
When i put US lights on my car (done it with 2 cars now) ive used the exsisting bulb holders so all the wiring stays the same. Ive found swapping in overseas bulb holders makes things stop working.
Forged 4G63 SOHC, Garrett GT30/76, Factory 3.9LSD, Custom MPI, Motec M4 ecu, 18s, Suspension, Bodykit, Gauge faces, Velour interior
Fitted with Star-Orion Parts
Playing with turbocharged Ford at the moment
From SQC chat-
ElkidminoLTU can't argue with Brendan, some of the chicks I sleep with..........well, we all make mistakes
#13 Austin88ESiR
Austin88ESiR
  • 1,838 posts
Posted 15 September 2008 - 03:30 AM
QUOTE (jd_stazza_brendan @ Sep 4 2008, 09:57 PM) <{POST_SNAPBACK}>
The bulb holders were the same, the were just wired to run as 1156 in an 1157 set up. I changed out the pig tails because they were not set up for running/brake lights.  The turn indicators should have stayed the same.  The fact that his hazzards work and his turn indicators come on but don't flash points to something else.  Without actually being there to test things, I am at a loss for suggestions.
#14 sactownca
sactownca
  • 42 posts
Posted 03 December 2008 - 11:25 PM
QUOTE (Austin88ESiR @ Sep 15 2008, 01:30 AM) <{POST_SNAPBACK}>
  Hello guys can somebody post the "Josh Tail lites mod" for some reason the link in NLA or does not work? Im trying to convert it to a PDF file for my self. thanks in advance RC
#15 damageinc86
damageinc86
  • 71 posts
Posted 23 February 2020 - 08:45 PM
That beyonddarwin website is down now.  Is this info still out there for the amber turn signal conversion?
#16 techboy
techboy
  • 3,717 posts
Posted 23 February 2020 - 09:38 PM
Try this link instead.
http://www.beyonddar...on/JDMtail.html
Edited by techboy, 23 February 2020 - 09:41 PM.
#17 techboy
techboy
  • 3,717 posts
Posted 12 May 2020 - 10:54 AM
So apparently that link is officially down now.  I haven't done the modifications to my car yet for the Euro tails, when I do I'll take pics, make a new thread, and document the process so we have a new resource for this.
#18 damageinc86
damageinc86
  • 71 posts
Posted 14 May 2020 - 02:39 AM
That would be nice.  Dead links suck.
