Fidanza Installation info
No replies to this topic
#1 mstieg
  • 6,144 posts
Posted 17 April 2013 - 10:15 PM
An old but good write-up on getting an alum. Fidanza resurfaced recently.  Old hat for some, but I didn't see it as a sticky, Trans/Clutch/Drivetrain FAQ, or in the Engine & Performance Mods forums.
If the OEM dowel is a bit loose, the 10x24mm Fasenol dowel part # is:  40079 to go into a new hole via a 25/64" drill bit.
In Progress: breakin & tune
