U joint replace...PICS.
66 replies to this topic
#21 Professor Quest
Professor Quest
  • 9,987 posts
Posted 08 November 2004 - 01:19 AM
Note the before and after pics of how clean you want the cap holders and the groove where the snap-ring goes. The pic tool will help clean the snap-ring groove.
#22 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 08 November 2004 - 01:23 AM
#23 Professor Quest
Professor Quest
  • 9,987 posts
Posted 08 November 2004 - 01:26 AM
A little cleaning solvent, a few swipes with the RAT-TAIL as usual, followed by the sand paper.
I can think of 2 other ways to do this without a vise. I'll spin the shaft around and do the other end without a vise. wink.gif
#24 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 09 November 2004 - 04:18 PM
#25 Professor Quest
Professor Quest
  • 9,987 posts
Posted 09 November 2004 - 04:36 PM
If you don't have a vise, this method works fine too. Here are some tips. Place your LEFT knee on the drive shaft to stabilize it. Use a 1" socket that has a THICK WALL or LARGER. This is to keep the BLOW AWAY FROM THE SNAP-RING GROOVE.........so you don't CRUSH IT. Reposition the wood if they jump out of place AS YOU GO!
#26 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 09 November 2004 - 04:40 PM
#27 Professor Quest
Professor Quest
  • 9,987 posts
Posted 09 November 2004 - 04:46 PM
Remember, strike only the weld. Same reaction! ;D
#28 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 09 November 2004 - 04:47 PM
#29 Professor Quest
Professor Quest
  • 9,987 posts
Posted 09 November 2004 - 04:52 PM
Driving the caps in a straight line helps, hence the block at the rear. Place your left knee about where the numbers are on the shaft. This will keep the shaft from bouncing.
#30 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 09 November 2004 - 04:53 PM
#31 Professor Quest
Professor Quest
  • 9,987 posts
Posted 09 November 2004 - 04:58 PM
#32 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 09 November 2004 - 05:01 PM
#33 Professor Quest
Professor Quest
  • 9,987 posts
Posted 09 November 2004 - 05:07 PM
"Something is making a CREAKING NOISE"!  You're looking at it. This is usually the FRONT U joint. Note on the LEFT SIDE of the cross. That's a hardend surface and it is TRASHED. NO.................you can't FEEL this with the shaft still in the car. But you will the minute you remove the shaft from the car.
#34 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 09 November 2004 - 05:08 PM
#35 Professor Quest
Professor Quest
  • 9,987 posts
Posted 09 November 2004 - 05:14 PM
A few more minutes with the wire wheel, a orbital sander with 60 grit worn down as you go........ and then wipe it down with lacquer thinner a couple times, and the other parts................I prime it, but to each his own. wink.gif
#36 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 09 November 2004 - 05:18 PM
#37 Professor Quest
Professor Quest
  • 9,987 posts
Posted 09 November 2004 - 05:38 PM
Napa sells the SUPER DUTY JOINT (not pictured-no zerk) under P/N 215-0088. The Napa standard joint is P/N 220-0088
The Carquest/SPICER joint (1-1516) is the SPICER 5-1516 $15.90. Spicer also makes the Neapco joint.
 Note the caps. Cap on left..........out of the box (not much grease).........cap on right, I filled with grease......ready to install. Filling the cap with grease HOLDS THE NEEDLES IN. VERY IMPORTANT! Also note warning on the BAG.
#38 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 09 November 2004 - 07:20 PM
#39 Professor Quest
Professor Quest
  • 9,987 posts
Posted 09 November 2004 - 07:23 PM
When you drive out the old caps........you will also leave a RIM of flashing. This FLASHING can now get caught up when you try to install the new cap. Sand the opening to remove the FLASHING..........8 openings to sand.
#40 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 09 November 2004 - 07:25 PM
