Brant Posted October 1, 2009 Report Share Posted October 1, 2009 Howdy all, I've got a boost guage installed in the OEM dash,now I need to know if I pipe it into the intakemanifold or ???? to get a boost reading. Thanks in advance, Brant Link to comment Share on other sites More sharing options...
dstar88 Posted October 1, 2009 Report Share Posted October 1, 2009 Howdy all, I've got a boost guage installed in the OEM dash,now I need to know if I pipe it into the intakemanifold or ???? to get a boost reading. Thanks in advance, Brant there are (i believe) 3 ports in a row and one port directly under those 3 on the intake manifold. Put it in the bottom single port. That bottom port sees boost and vacuum all the time, so it should give you a good reading there. If your car is an automatic there is also a port on the #4 runner of the intake manifold that you can probably use. If your car is a manual, you will still have that port on the #4 runner but it will be plugged. But i still suggest using that bottom port on the intake manifold. Daniel Link to comment Share on other sites More sharing options...
Brant Posted October 1, 2009 Author Report Share Posted October 1, 2009 Cool Link to comment Share on other sites More sharing options...
Brant Posted October 1, 2009 Author Report Share Posted October 1, 2009 Sorry, still not getting it, I'm learing impaired. How about a pic? Brant Link to comment Share on other sites More sharing options...
dstar88 Posted October 2, 2009 Report Share Posted October 2, 2009 if i can find one of that area ill post one up for ya. Daniel Link to comment Share on other sites More sharing options...
mikec Posted October 3, 2009 Report Share Posted October 3, 2009 Is it a vacuum+boost gauge? Or just a boost (pressure) gauge? They connect differently.Vac+boost gauge: stand at the driver side fender and look at the intake manifold + injection mixer (throttle body) assembly. You'll see a spot where three vacuum hoses connect in a horizontal row. Either "T" into the one closest to the firewall (the bodywork between the engine and interior) or to the slightly larger vac port about 2 inches below the "row of three." boost/pressure only gauge: See the metal pipe crossing above the engine? Follow it to where it connects to the injection mixer. Just past that connection there is a vacuum port pointing towards the front of the car. That's a good one to "T" into. mike c. Link to comment Share on other sites More sharing options...
