cooljs78 Posted August 16, 2009 Report Share Posted August 16, 2009 Is my vacuum pump located in the front next to the driver side headlight? If so mine has a short vacuum line hanging that is not hooked up! I cant find were it goes and what it controls!? Link to comment Share on other sites More sharing options...
mikec Posted August 16, 2009 Report Share Posted August 16, 2009 The vac pump is for the cruise control. It supplies vacuum when the engine is running on boost pressure and has no intake manifold vacuum. The vac hose from the top of the pump should run along the front bodywork panel (above the grill) and then pokes through to the engine bay near the air filter box. It continues and plugs into a "T" near the gold colored cruise control actuator. mike c. Link to comment Share on other sites More sharing options...
cooljs78 Posted August 16, 2009 Author Report Share Posted August 16, 2009 The vac pump is for the cruise control. It supplies vacuum when the engine is running on boost pressure and has no intake manifold vacuum. The vac hose from the top of the pump should run along the front bodywork panel (above the grill) and then pokes through to the engine bay near the air filter box. It continues and plugs into a "T" near the gold colored cruise control actuator. mike c. thanks Link to comment Share on other sites More sharing options...
