vizion Posted August 3, 2009 Report Share Posted August 3, 2009 what is everybody's fave fuel ignition management for starions ? just doing research. I'm thinking of using AEM F/IC if i figure out all the cabling. Eric Link to comment Share on other sites More sharing options...
Elkidmino Posted August 3, 2009 Report Share Posted August 3, 2009 what is everybody's fave fuel ignition management for starions ? just doing research. I'm thinking of using AEM F/IC if i figure out all the cabling. Eric Most common seen units are: -Megasquirt -FIP (Fuel Injection Pro) -SDS (Simple Digital Systems) -Hawk Sky's the limit. Many go for fuel and ignition control combined. There are options from there to go on down the list of "how to control" spark. Many use what they are comfortable with. Link to comment Share on other sites More sharing options...
vizion Posted August 3, 2009 Author Report Share Posted August 3, 2009 thanks, man. Eric Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted August 4, 2009 Report Share Posted August 4, 2009 AEM FI/C is a piggyback and won't likely control a MPI setup unless you can figure out how to split injector drivers to run four injectors from the stock ECU's antiquated fuel maps. Link to comment Share on other sites More sharing options...
vizion Posted August 4, 2009 Author Report Share Posted August 4, 2009 thanks, justpaus. standalones would be best then. Eric Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted August 4, 2009 Report Share Posted August 4, 2009 If you're talking MPI, then yes a standalone is your best bet. What I would suggest is to find out about your local tuner crowd and who they trust to tune their cars. Whoever the tuner is will definitely have his favorites, which will limit you in terms of which standalone you can realistically run. Unless you can(or know a friend that can) tune your setup, so you'll just need to rent a dyno and go from there. For example, I only trust one shop here and they have more experience with AEM/Pro-EFI/Motec, so things like SDS/Haltech/Autronic wouldn't be in my best interest to try and use. I could go MegaSquirt, but would have to rely on a local(non-shop owner/worker/tuner) enthusiast and rent dyno time to get it tuned that way. Link to comment Share on other sites More sharing options...
vizion Posted August 4, 2009 Author Report Share Posted August 4, 2009 my local tuner speaks AEM so maybe we'll try the 30-1900u. It's for a supercharger project. Link to comment Share on other sites More sharing options...
