cudabnu Posted February 15, 2004 Report Share Posted February 15, 2004 Just got done! Idles smooth! I'll wait to break in the cam for a few days before I abuse it, then test it with the G-tech . then LACR Raceway in april. Other mods: OVCP w/ RFL BOV 3" Exhaust W/ flowmaster 1G MAS W/ AHP HKS AFR Wideband O2 20G Turbo Joe P electronic MBC Stock Engine with about 87K miles on it. Clutch is starting to slip, will be installing a ACT Extreme PP and lightened flywheel in 2 weeks. After this is done, Then I will start building the race motor, Just need a block and crank. I have ready to go Marnal head Magna MPI Modified by Chad SDS w/ 72 lb injectors Ross Pistons Corrillo H-beam rods Weld Pro Stars w/ 10" slicks (Thanks Buscher Racing!) Link to comment Share on other sites More sharing options...
backslider Posted February 15, 2004 Report Share Posted February 15, 2004 Stay clear of Ross pistons. I wouldnt use them again. Link to comment Share on other sites More sharing options...
pumpedTSI....... Posted February 15, 2004 Report Share Posted February 15, 2004 Not just Ross..........JE blow the big one too...........stick with Wiseco....... Link to comment Share on other sites More sharing options...
cudabnu Posted February 15, 2004 Author Report Share Posted February 15, 2004 I know tons of guys with first gen DSM's that use the ross pistons with no problems, they prefer them over the wiseco's, and definately over the JE's Link to comment Share on other sites More sharing options...
backslider Posted February 15, 2004 Report Share Posted February 15, 2004 With Ross , you are limited to certain piston rings. A small selection I found out. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted February 15, 2004 Report Share Posted February 15, 2004 I know tons of guys with first gen DSM's that use the ross pistons with no problems, they prefer them over the wiseco's, and definately over the JE's The 4g63 and g54b are totally different planets.... Link to comment Share on other sites More sharing options...
cudabnu Posted February 15, 2004 Author Report Share Posted February 15, 2004 The 4g63 and g54b are totally different planets.... True, but what does that have to do with piston choice? Both engines still see large amounts of boost, the concept is still the same. Thats like saying a TRW forged piston is fine in a Chevy but not in a Mopar. Makes no sense. What are the limited rings choices for Ross? I have file fit Total seal rings, I only need one choice. I base my decision on material used to make the pistons, and other people that I know that run insane amounts of boost with no problem. If you thing the pistons are bad and to stay away, then lets hear why! J.E. pistons tend to have some slap because of the material they are made of. Wiseco are made with better materials, better piston. Same with Ross. I do alot of research before spending that kind of money, I only want to build this once. I'm just curious why you guys say so stay away from ross, because if it's only based on "ring choice" then, well.....your crazy! Link to comment Share on other sites More sharing options...
pumpedTSI....... Posted February 15, 2004 Report Share Posted February 15, 2004 For some reasons on why not JE, go to the top of this forum and read "cracked forged pistons", theres MY reason Link to comment Share on other sites More sharing options...
Joel Posted February 15, 2004 Report Share Posted February 15, 2004 20 minutes, 2000RPM and the cam is never gonna break in more than that. Keep it there for 20minutes to keep the oil pressure up. Joel Link to comment Share on other sites More sharing options...
cudabnu Posted February 15, 2004 Author Report Share Posted February 15, 2004 Sweet, then I'm going to give it a good "testing" tonight! Thanks Joel! Link to comment Share on other sites More sharing options...
cudabnu Posted February 15, 2004 Author Report Share Posted February 15, 2004 For some reasons on why not JE, go to the top of this forum and read "cracked forged pistons", theres MY reason yes, i read that and responded to it a long time ago, also if you look at his dyno when it happened, he was running way too rich! which can obviously have bad effects! Basically the Je's need looser clearences because of expansion, where the Ross and Wiseco's do not, they can run tighter clearences because of the material they are made of. Link to comment Share on other sites More sharing options...
backslider Posted February 15, 2004 Report Share Posted February 15, 2004 I didnt want to run total seal rings again. I couldnt find anything else that fit in the 3mm ring grooves. My last set of total sels were toast from my air filter having a small hole in it. Link to comment Share on other sites More sharing options...
cudabnu Posted February 15, 2004 Author Report Share Posted February 15, 2004 I didnt want to run total seal rings again. I couldnt find anything else that fit in the 3mm ring grooves. My last set of total sels were toast from my air filter having a small hole in it. Were they the "total seal" or the file to fit? Link to comment Share on other sites More sharing options...
pumpedTSI....... Posted February 15, 2004 Report Share Posted February 15, 2004 Come to think of it............my JE's were always "slappy"..........never did get used to that nor like it much. Link to comment Share on other sites More sharing options...
