h2o guage
vb472
I just bought a aftermarket water temp guage.
has any one hooked up any aftermarket guages?
i tried hooking the wire up to the factory temp sensor and all it will do is max out.
if i use the sensor that came with the guage can i still hook up the factory temp sensor?
On a stock manifold thier are two sources for the temp,. the normal one pointing at you,. an the one lower,. next to the neck. of the thremo housing.  thats why it spiked, becasue you only hooked one of them. probably the one pointing at you, toward the top of the manifold, next to the thermo housing.
Just below it an to the left.  the stock temp,.. is ran from both sensers on the intake.  An the reason why your aftermarket spiked, to the end.  was becasue it wasnt connected to the other temp senser.  im not exactly sure why in the hell it does it,.. but it does.
