turboquestDMC Posted December 21, 2004 Report Share Posted December 21, 2004 I need to get the rear light cover off, to replace the right reverse bulb to pass inspection. Help. Link to comment Share on other sites More sharing options...
D_Venable Posted December 21, 2004 Report Share Posted December 21, 2004 Open the hatch, then on the rear most interior trim piece, there should be 2 small trim pieces that come off when you pull on them. There is one on each side (on vertical section). Once these are off, you should be able to see the wiring harness for the taillight assembly. from there you can just twist the reverse light bulbs socket counter-clockwise and it should loosen up allowing you to pull the bad bulb and replace it. Hope this helps Derek Link to comment Share on other sites More sharing options...
