backslider Posted September 21, 2002 Report Share Posted September 21, 2002 I want to hook up a amp but it seems my antenne has power all the time. Could that be due to the fact that someone broke the antenne? I was probing a 5 wire connector that goes to the back of the antenne. Two remained hot at all times except for when the antenne went up or down. Only during those two movements did the power switch to somewhere else. Any ideas on if this is a problem or am I at the wrong connector? Link to comment Share on other sites More sharing options...
wmss33 Posted September 22, 2002 Report Share Posted September 22, 2002 you need to find the ingnition wire to your radio and splice into it. you can how ever connect the turn on wire for your amp to the fuse for your radio I wouldn't recomend this but it will work.I wll try to look tomorrow at my wire and tell you which one it is. Hope this helps. Btw how do you have the turn on wire, wired up to?? wmss33 Link to comment Share on other sites More sharing options...
Elias Posted September 22, 2002 Report Share Posted September 22, 2002 you have to unplug the connector for the power antenna controller, under the metal panel in the spare tire area. Link to comment Share on other sites More sharing options...
