sqall12001 Posted October 21, 2015 Report Share Posted October 21, 2015 Ok, very brief history, owned since like '03? Large turbo, ect ect. Sat for several years,3-8 years ago, some trips in between (maybe 50 miles) last 2 years, maybe 3 small trips. Had Turbo heat shields off Got going a week or so ago to play with for the last month of season, Got Gas, on interstate to work, on it a couple times. Then started to Missfire, but sounding unlike what i'm used to in her. So far, checked and cleaned plugs (Trying cheap new one's tomorrow just to see, Compression tested (Low but from where I remember it before, similar to previous readings, 90,80,80,90) Turbo spins good. If driving under a vacuum, no load, runs/sounds fine. Anywhere near 0PSI or boost, instant sputter. Switched Fuel injector clips, Got 10 more gallons, added advcanced auto fuel system treatment. Digging in further tomorrow, just Pooling you 'gents for any insight. Thanks!!-Nick Link to comment Share on other sites More sharing options...
sqall12001 Posted October 21, 2015 Author Report Share Posted October 21, 2015 Not sure if I may have toasted a wire? Taylor 8.5?mm wires (Hence mentioning heat shield off) I attached sound file, you guys seeing?? -Nick Link to comment Share on other sites More sharing options...
sqall12001 Posted October 21, 2015 Author Report Share Posted October 21, 2015 (edited) http://vidmg.photobucket.com/albums/v509/Sqall12001/Quest%20Grumpy_zpsehlcjnqu.mp4 Edited October 21, 2015 by sqall12001 Link to comment Share on other sites More sharing options...
sqall12001 Posted October 21, 2015 Author Report Share Posted October 21, 2015 The Stutter in the middle is fairly normal and am not to concerned about that part, just the "Exhaust tapping" Also, no noticeable lifter noise -Nick Link to comment Share on other sites More sharing options...
sqall12001 Posted October 22, 2015 Author Report Share Posted October 22, 2015 Wow, no replies. Found I cooked a sparkplug. -Nick Link to comment Share on other sites More sharing options...
