1987 Starion ESI - $2500 OBO
JessN16
1987 Starion ESI 5-speed for sale, asking $2500 OBO.
The good:
* Southern car with no frame rust.
* Suspension Techniques lowering springs and Tokico Blue struts.
* Brand-new Yokohama S-Drive tires. Less than 100 miles on the whole set.
* About $2,000 in stereo equipment comes with it, including an Xtant amplifier, Kenwood double-DIN radio with 12-disc changer, and Sirius Satellite Radio with active subscription, as well as a pair of Boston Z7 speakers.
* Rebuilt steering rack, still in the box I ordered it in (factory one is fine, it just leaks a little)
* New factory clutch (less than 1,000 miles)
* Tinted windows
* Functioning A/C (although it's stuck in dash mode, no foot vents)
* Custom adjustable Zirgo cooling fans and new radiator
* BSE elimination
* Alabama non-JV head
* 16G turbo (will need rebuild soon but it's not imminent)
* 1988 igniter upgrade
* MOMO steering wheel and real carbon-fiber MOMO shift knob, as well as carbon-fiber instrument cluster gauge surround and see-through gauges
* Slotted rotors and race-level performance brake pads
* Upgraded to 88 flywheel
The bad:
* Shifter needs to be rebuilt. Will access all gears but only goes in 1, 3 and 5 easily. This must be addressed pretty quickly, and is the reason the car has been parked the last four months.
* Needs an exhaust system update. The stock exhaust is still on the car (precat has been deleted) and the muffler is pretty much gone.
* Seat leather is hard.
* Most of the gauge cluster is non-functioning, including the speedo, oil and water gauges. Odometer still works, though.
* Although it has no frame rust, there is one piece of surface rust that needs to be addressed. Something hit the hood, either a rock or a hailstone, a few years ago. It cracked the paint there and now there's a spot about 2-3 inches across, circular, that has surface rust only. The full hood will need to be stripped and painted.
* High mileage (207k, I think)
* Original 87 airdam is still on the car but just barely.
This is absolutely a perfect car for someone wanting to do a motor swap. There's nothing wrong with the block in this car, but the sheer mileage may put some people off.
The shifter issue is the only gotta-fix-it-no-matter-what problem it has right now. The car wasn't just running when I parked it, it was my daily driver.
Car is located in central Alabama.
Jess
Edited by JessN16
  • 2 weeks later...
  • 4 weeks later...
The good:
* Tinted windows
* BSE elimination
The bad:
Jess
hi, i am interested in buying this car pklease call me at 770-771-3928 eric. thank you.
  • 3 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
