Posting Pictures Hosted On Photobucket
  • This topic is locked This topic is locked
No replies to this topic
#1 Dred_85.5_TSI
Dred_85.5_TSI
    Flatty Love
  • 2,215 posts
  • Interests:I have an announcement to make, "Turbo........ That is all".
Posted 28 September 2011 - 08:01 PM
OK, so you have a SQ and now you want to show off your new ride? Here is how you upload pictures from your computer to a site, I'm using Photobucket (http://photobucket.com), and then using the site to host the images post your pictures on SQC.
Step #1:
Starting in your Photobucket album you can see the "Upload" tab. Left click this tab.
Step #2:
Now you can see options for uploading pictures and videos. You can drag and drop files, or, browse files. I will be browsing files. Left click on the "browse files" button.
Step #3:
Now you can select the pictures you want to upload to Photobucket. Select the pictures and left click "Open". This will begin the upload.
Step #4:
Once the upload is finished you will see the upload success screen. You should now left click the blue "View Library" button. This will take you back to your album view where you can see the new picture.
Step #5:
Now you can either hover the mouse pointer over the "gear icon" in the top right of the picture and the link and tag options will appear, or, you can double click on the picture and you will come to a single picture view where your options are easier to understand. You will want to use the IMG code option on the right side of the screen, left click on the text in the IMG code box. This will copy the IMG code.
Step #6:
Now you can start a new topic on Star Quest Club. Right click on the text box (or ctrl+v) in your new post and select "Paste" this will paste the image code from Photobucket. Now you can add the text part of your post. A good idea at this point is to "Preview Post" to make sure the IMG code works. Assuming that works, you will want to click the "Post New Topic" button under the text box.
Step #7:
Now you should see this
Step #8:
Continue to post pictures on SQC.
Edited by Dred_85.5_TSI, 21 March 2013 - 08:55 PM.
Posted Image   1984 Starion ES: Currently running 15psi, Stock block (ARP main and head studs rod bolts, Clevite bearings) BSEK, M28 NJV head with mechanical valve train gasket matched on intake and exhaust, Treadstone exhaust manifold and Holset HX35w with BEP turbine housing, MK1 3" stainless exhaust, Old skool HKS super BOV, 3" GM MAF with MAFT, Artinist's old 4" core intercooler, custom Aluminium hard pipes, S13/SR20 Aluminium radiator w/clutch fan, Innovate LC-1 wide band O2, `83 crank pulley with A/C removed.
   `88 5 speed trans with Stedbani short shifter, Stedbani poly trans mount and engine mounts, drilled and slotted rotors, Joly roger stainless steel braided lines(brake, clutch, oil cooler, and ABS delete).
   KYB GR2, Artinist sleeve coil-overs, MK1 poly bushings, Energy Suspension poly end links, MK1 Adjustable tension rods, Cusco front camber plates, Artinist slotted rear camber plated.
ABS, A/C, Cruise control.. deleted, Right hand drive E-brake handle.
... more to come
Feedback:
Feedback thread #1
Feedback thread #2I'm PayPal Verified
