flatty86 Posted January 23, 2013 Report Share Posted January 23, 2013 Hey guys. I'm having a hard time removing my driveshaft. Do I have to remove the Torque tube in order to remove the driveshaft? or is there another way to remove the driveshafe with out doing that? Please help!!! I'm in the middle of workig on it right now. Link to comment Share on other sites More sharing options...
Starwolf Posted January 23, 2013 Report Share Posted January 23, 2013 You do not need to remove the torque tube to remove the driveshaft. The driveshaft has 8 bolts total to remove. Pretty straight forward except you might have to turn the driveshaft to get a bolt or two Link to comment Share on other sites More sharing options...
flatty86 Posted January 23, 2013 Author Report Share Posted January 23, 2013 i only counted four.... where are the other 4? Link to comment Share on other sites More sharing options...
ColdScrip Posted January 24, 2013 Report Share Posted January 24, 2013 4 bolts w/nuts near the rear of the vehicle. You must turn it to get to the other bolts so make sure the rear wheels are up and the tranny in neutral. After those 4 bolts are out you can let that end of the driveshaft fall down and then you slide the other end out of the tranny. Link to comment Share on other sites More sharing options...
Starwolf Posted January 24, 2013 Report Share Posted January 24, 2013 Derp yeah 4...I don't know why I was counting 8.I win Link to comment Share on other sites More sharing options...
flatty86 Posted January 24, 2013 Author Report Share Posted January 24, 2013 thanks guys I got it.. after removing the bolts the shaft was so rusted that it wouldn't come off... after lubing it and a little prying it finally came off. Thanks again. Link to comment Share on other sites More sharing options...
flatty86 Posted January 25, 2013 Author Report Share Posted January 25, 2013 oh man... so I took the car out for a test drive today and new issue since installing the driveshaft... When I down shift the car violently vibrates... The car even got stuck where it wouldn't come out of gear no matter how hard I tried to force it out....I was stranded for an hour or so,,,, Is there a possibility I got the wrong driveshaft? I mean this drive shaft was off of a 87 tsi and mines a flatty.... there is a small difference between the two... my flatty have a grove in the shaft whereas the TSI does not,,, Could this be my issue? Please help. Link to comment Share on other sites More sharing options...
