nicksquest Posted June 2, 2010 Report Share Posted June 2, 2010 this may be a dumb question but where is the fuse for my doors power. i looked at the fuse block in the car on the side of the dash the one with the cool tester. felt some loose fuse's but didnt find any that are blown ones. should i be looking at some thing else? cleaned the window switches well i was trying to get them to power. no luck!!thanks for you help!! Link to comment Share on other sites More sharing options...
lew39 Posted June 2, 2010 Report Share Posted June 2, 2010 check your fuseable links by the battery. i have an 86 and the power window link is the green one closest the battery. should probably pull the neg off the batt before cleaning or fiddleing with them. Link to comment Share on other sites More sharing options...
nicksquest Posted June 2, 2010 Author Report Share Posted June 2, 2010 check your fuseable links by the battery. i have an 86 and the power window link is the green one closest the battery. should probably pull the neg off the batt before cleaning or fiddleing with them.thanks i will try this after i get my starter in and put the vac lines back on proper. Link to comment Share on other sites More sharing options...
