square peg in a round hole "fitech build"
fitech 600PA blow-through
3 replies to this topic
#1 kezark31
kezark31
  • Newbies
  • 2 posts
Posted 01 May 2021 - 06:49 PM
hello everyone i just want to share my adventure. I have an 87 starion ive had it for a couple years now. about 8 months or so ago i got the itch to try something different. so i took the sawsall and literally cut the center section out of the stock intake i made a steel adapter that kind of resembles a "cow bell"  with a flange for a 4 bbl carb on one end. when i first set the car up i was running fuel only with the stock ignitor and knock box, i wanted the fitech to control the timing so i have got that done now im still tweaking the tables but the car is up and running i have a couple videos on youtube if anyone is interested or intrigued i will try and get pix up late
my brainstorming
here you can see ive ground off the coolant passage and removed the area where the factory coolant temp sensor goes, i had a local welding shop weld up the hole left over. best 20 bux i spent haha
here is my square peg booted to the stock intake i also had to retap the coolant port for a gm temp sensor
so the fancy carb hat didn't work out hit the hood and the valve cover
Edited by kezark31, 02 May 2021 - 01:28 PM.
#2 kezark31
kezark31
  • Newbies
  • 2 posts
Posted 02 May 2021 - 02:00 PM
https://youtu.be/zeKUV0Tv_W4
#3 Funky Phil
Funky Phil
    Super Pooper
  • 6,499 posts
Posted 04 May 2021 - 10:16 AM
I am watching! Got similar plans
#4 obsolete
obsolete
  • 598 posts
Posted 04 May 2021 - 11:06 AM
Cool. Idles better than a lot of cars with the factory setup do these days. Pictures are tiny, wish we could get some bigger ones.
#5 psu_Crash
psu_Crash
  • 7,479 posts
Posted 09 May 2021 - 05:05 PM
Same thing I though. Need better pics!
Agreed that thing idles nice! Much better than my car when it's cold
The Valencia Project
My Feedback Link
