Has anyone ever done a rack and pinion swap to a mustang 2 rack and pinion?
9 replies to this topic
#1 BrycexD
BrycexD
  • 18 posts
Posted 01 May 2021 - 09:35 AM
Finished mine 5 or 6 months ago and I canít seem to find any instance of anyone else doing this. Anyone know of someone thatís done this?
#2 tux
tux
  • 1,763 posts
Posted 01 May 2021 - 10:30 AM
Nope, did you happen to document it?
#3 BrycexD
BrycexD
  • 18 posts
Posted 01 May 2021 - 10:40 AM
Yes I have a ton of pictures of the process but itís not 100% complete. Thereís one minor issue Iíve run into which was why I was searching for another instance of this swap to see how they resolved this.
#4 obsolete
obsolete
  • 598 posts
Posted 01 May 2021 - 05:34 PM
Mustang II rack is front-steer, Starquest spindles are rear-steer. How did you solve that? I think that's the reason it's not commonly done.
#5 BrycexD
BrycexD
  • 18 posts
Posted 01 May 2021 - 08:02 PM
Thereís a piece that bolts to the bottom of the spindle (not sure what itís called) which also has the steering arm on it. I just flipped it around backwards, slightly bent the steering arm down and reinforced it.
#6 psu_Crash
psu_Crash
  • 7,479 posts
Posted 01 May 2021 - 08:38 PM
Curious to see how this was done.
The Valencia Project
My Feedback Link
#7 BrycexD
BrycexD
  • 18 posts
Posted 01 May 2021 - 09:47 PM
Iíll start another thread with pictures and explanations when itís fully finished and the one issue Iím having is resolved.
#8 j.quest
j.quest
  • 560 posts
Posted 03 May 2021 - 10:32 AM
what about the 240 sx , front end swap   +?
#9 tux
tux
  • 1,763 posts
Posted 03 May 2021 - 11:26 AM
that's covered in other threads.  I'm interested in this mustang II rack swap
#10 obsolete
obsolete
  • 598 posts
Posted 03 May 2021 - 11:51 AM
View PostBrycexD, on 01 May 2021 - 08:02 PM, said:
There's a piece that bolts to the bottom of the spindle (not sure what it's called) which also has the steering arm on it. I just flipped it around backwards, slightly bent the steering arm down and reinforced it.
Gotcha. Have you checked the Ackermann geometry after doing that?
