ECU Check - where and how-to?
ECU diagnostic tool how-to
6 replies to this topic
#1 Kanye9
Kanye9
  • 18 posts
Posted 21 February 2017 - 05:25 AM
<p>Hi Starquest fans,
I need YOUR help &#55357;&#56861;
Let me explain -
Global issue is - car doesn't run as expected -
Flow:
1. Start engine
2. Push gas, all fine and reaches 5k rpm without problems
3. Back to idle
4. Push gas and you can see that it becomes difficult to go over 2k rpm
Observations: the problem seems to begin when turbo starts to deliver power ( i.e when charged and start)
THEN if we stop engine
Restart,
It goes like 1.
Then again the same scenario over and over.
Infos:
2.0 1982
Done
checked and cleaned tank
Replaced all filter
Not yet done
check electric cables to injectors
check injectors
check ECU (Because I dont know what, where and how-to)
Thanks for helping me !
Edited by Kanye9, 21 February 2017 - 05:28 AM.
#2 importwarrior
  • 18,412 posts
Posted 21 February 2017 - 05:49 AM
usually when i see this it seems the injector ( Secondary injector ) works for a short time then just dies out.
replace secondary injector if you have one and try again.
i had a 9 volt battery and hooked the injector to it with a button switch. when i repeatedly turned on and off you could hear and feel the clicking was good for the first 10 cycles and then it slowly got worse and eventually didn't click open any more. it seems it is just worn out internally.
#3 Kanye9
Kanye9
  • 18 posts
Posted 21 February 2017 - 06:05 AM
First,thanks for your fast reply
Attention point!
my starion is a 2.0 and then doesnt have 4 injectors.
And don't have any injector right here :/
So, as solution, replace the ECU? :o
Edited by Kanye9, 21 February 2017 - 06:06 AM.
#4 scott87star
scott87star
  • 5,135 posts
Posted 21 February 2017 - 10:07 AM
It's not the ECU, they hardly ever go bad.
#5 ucw458
ucw458
  • 11,769 posts
Posted 21 February 2017 - 01:17 PM
Regardless of engine or year, no SQ came with 4 injectors.  83-86 have 2 injectors the same size that spray at the same time.  87-89 has a primary and secondary injector.  They are different flow rates.  The bigger secondary comes on around when the turbo makes boost.  If that one may be faulty.  I would suggest replacing the injector electrical connector first.  It's a bosch EV1 style connector.  Polarity doesn't matter.
Also check the vacuum advance inside the distributor.
My 87
#6 markhansenconquest
markhansenconquest
  • 3,809 posts
Posted 21 February 2017 - 04:29 PM
Did u clean the screens in the top hat?
#7 Kanye9
Kanye9
  • 18 posts
Posted 22 February 2017 - 03:43 AM
Thanks for your answers,y're awesome ;)
I already check the vacuum but will check/replace the connector to injector.
K.
Also tagged with one or more of these keywords: ECU, diagnostic, tool, how-to
