EGR removal question
7 replies to this topic
#1 BlueCuda
BlueCuda
  • 17 posts
Posted 07 June 2021 - 05:53 AM
I recently bough an 87 that had a blown head gasket and it is apart.  I am in the process of cleaning that mess up at the moment.
The EGR was just looped off with vacuum lines.  I would like to delete it completely.  Is there any issues with either tapping the port going to the head to put a pipe plug in it or just finding the right sized plug to tap in there?  It would keep a little heat out of the intake and allow removal of the valve best I can tell.
87 Conquest M5 project
#2 scott87star
scott87star
  • 5,135 posts
Posted 07 June 2021 - 06:26 AM
Iíve always just made a small block off plate and bolted that over the holes.
#3 kev
kev
    Moderator
  • 5,355 posts
Posted 07 June 2021 - 07:09 AM
Yes, you can drill/tap the port in the head and install a plug.
#4 techboy
techboy
  • 3,887 posts
Posted 07 June 2021 - 08:32 AM
X2 for both posts above this.  I've done the same thing with no ill effects.
#5 tux
tux
  • 1,791 posts
Posted 07 June 2021 - 10:01 AM
you can buy a block off plate from ebay pretty cheap. 14$
#6 kev
kev
    Moderator
  • 5,355 posts
Posted 07 June 2021 - 10:54 AM
Pretty self explanatory but figured I'd mention it, even if you plug the port in the head, you will still need a block off plate for where the EGR valve was...or leave the EGR valve on provided it is not stuck open.
#7 BlueCuda
BlueCuda
  • 17 posts
Posted 08 June 2021 - 05:29 AM
Agreed on the block off plate.  Thanks!
#8 psu_Crash
psu_Crash
  • 7,497 posts
Posted 08 June 2021 - 08:41 PM
Never thought about drilling and putting a plug in. That's genius!
The Valencia Project
My Feedback Link
