Tien flex adapter and d2 question
28 replies to this topic
#1 tux
tux
  • 1,811 posts
Posted 11 June 2021 - 09:44 PM
Anyone happen to look into using this with d2's?
https://www.tein.com...controller.html
I wonder if they will fit the coilovers and i can reach through the rear side carpet pieces
Edited by tux, 12 June 2021 - 02:02 PM.
#2 87redcat
87redcat
    10 years and counting...
  • 4,179 posts
Posted 12 June 2021 - 12:20 PM
Interested...
#3 TexasQuest
  • 9,252 posts
Posted 12 June 2021 - 10:21 PM
Only one way to find out....
88 Fiji Blue -TSi
#4 tux
tux
  • 1,811 posts
Posted 12 June 2021 - 10:29 PM
Looks like I'm buying them
#5 tux
tux
  • 1,811 posts
Posted 14 June 2021 - 09:09 AM
The only issue is how to buy them >.<
If these fit, that means that people can use the TEIN EDFC PRO and ACTIVE damping controllers. as they will connect the same way.  I'm not interested in the electronic controllers, but others might be.
#6 obsolete
obsolete
  • 622 posts
Posted 14 June 2021 - 09:39 AM
https://www.rallyspo...ended-adjusters
BC makes something similar, and I think other brands do as well. Something has to be close enough to work with the D2s.
#7 tux
tux
  • 1,811 posts
Posted 14 June 2021 - 12:08 PM
Apparently D2 makes these and it's not published anywhere!  I just ordered some direct from D2 for 15$ each.  The extensions d2 sells come in 350mm length only which should be long enough to route from behind the side panels.
#8 tux
tux
  • 1,811 posts
Posted 14 June 2021 - 12:14 PM
hm... d2 has some rear big brakes with OE handbrake functionality... only brand i've seen with this, but they are $$$$ and not specific to the car.
#9 obsolete
obsolete
  • 622 posts
Posted 14 June 2021 - 12:22 PM
Awesome! Got a part number or link? Did you have to call or e-mail them to order?
#10 obsolete
obsolete
  • 622 posts
Posted 14 June 2021 - 12:23 PM
Wilwood makes universal rear calipers with integrated handbrake too.
#11 tux
tux
  • 1,811 posts
Posted 14 June 2021 - 02:42 PM
just email info@d2racing.com part number is  D2-COKFLXDMP they will sell direct.
Part isn't listed anywhere on the website.
Edited by tux, 15 June 2021 - 07:40 AM.
#12 tux
tux
  • 1,811 posts
Posted 14 June 2021 - 02:43 PM
Do you have a partnumber?  I only see the separate caliper from them for the e-brake
#13 obsolete
obsolete
  • 622 posts
Posted 15 June 2021 - 09:21 AM
There are three of them; two actually have the same piston diameter as the Starquest rear caliper: https://www.wilwood....ination P-Brake
#14 Turbo Cary
Turbo Cary
  • 1,944 posts
Posted 15 June 2021 - 12:29 PM
I am running wildwood calipers front and rear on the Miata but the rear e brake is lacking. Have the cable tightened almost all the way and it barely holds the car on a big slope. really they just clamp the pads together with a spring system and not really through the caliper pistons.
#15 tux
tux
  • 1,811 posts
Posted 15 June 2021 - 12:31 PM
Hm ok.  probably why brembo only makes the second caliper specifically for parking
#16 obsolete
obsolete
  • 622 posts
Posted 15 June 2021 - 12:35 PM
Oh, that's lame. Didn't know that.
#17 tux
tux
  • 1,811 posts
Posted 16 June 2021 - 10:54 AM
I just got the D2 extensions... Not as I expected.  They don't look as well made as any other company very short sheathing and very long cable exposed.  I don't see any way to secure this cable to the strut other than epoxy or something.  Other vendors have full sheathing and a gland at the end with a set screw to secure to the body.
Posted Image D2's version.
I've got a ping out to D2 about this.  Waiting response.
Also maybe to note, I've got the D2 Aircup Kit that came in as well.  Cheaper to install this than make my driveway approach reasonable for anything other than an SUV.
Edited by tux, 16 June 2021 - 10:59 AM.
#18 tux
tux
  • 1,811 posts
Posted 16 June 2021 - 11:26 AM
Update: D2 did not think it was necessary to secure to the coilover top.  They recommended just "friction fit", glue, or for me to invent a solution.  I'm ordering a set from another vendor.
If these fit the "legion elite" coilovers I have and am planning to put in the other car, I'll tack them on somehow.
#19 Turbo Cary
Turbo Cary
  • 1,944 posts
Posted 16 June 2021 - 02:48 PM
I could probably adjust mine tighter but I didn't want to stress the cables that bad. I keep a wheel chock in the trunk in case I end up on some insane hill or slope. But for drifting I'd need to use a hydraulic setup if I wanted to rely on E brake drifting. Instead I just rely on the cars power and properly shifting it's weight around
#20 Turbo Cary
Turbo Cary
  • 1,944 posts
