conquestpa
Everything posted by conquestpa
Honda MPI for Starquest
conquestpa replied to YELLOWHELL's topic in MPI/Standalone Trials and Tribulations
I dont think the 2.6 with balance shafts will like doing 9K RPM... -
Need help, no spark.
conquestpa replied to 88TSI_Rob's topic in MPI/Standalone Trials and Tribulations
Make sure the body of the GM module is grounded!!!!!!! Also, if its a old stock coild consider going to the auto parts store and getting a nice new accell chrome performance coil for about $30.... -
doubtful.
ahh, coolant leak from Magna adapter plate!
conquestpa replied to Jonathan's topic in MPI/Standalone Trials and Tribulations
Whoops, here's my answer from another thread: You can use the stock gasket where it meets the head. The rear water passage is resized so it has everything the same as the stock intake (atleast on the ones I mod, don't know about the others). The plenum to manifold seal can either be cut, or use some RTV glue (gasket glue). It's just air passing though there, no water/oil so that should be plenty safe, cheap, and easy. -
How come I never got an adaptor plate? I got a unmodded magna intake manifold and Chad moddified it for me. I had it test fitted with a gasket I made up, and ran it, no leaks. But now I have a slight coolant leak coming from the somewhere around the intake. Its very possible that this is leaking from somewhere else weird around there. Im also curious about what type of gasket we would use here if we wanted to buy one. I assume you could buy one for the US style intake manifold and make it work. -
Buy my car.
TD05, TD05h, TD06, T3/T4...
conquestpa replied to Pounder_Pit's topic in Engine, Exhaust/Intake, Turbo
OK, this should be in the FAQ area! -
how about some pics?
Chad modded my manga intake manifold, so far so good. Really great to deal with, he even gave me a 1G DSM BOV and a real nice aluminum t pipe for it as part of the manfold deal. A+, highly skilled and I don't think hes going anywhere any time soon ( he isn't going to disappear on you).
http://www.starquestclub.com/forums/viewto...&highlight= :cry:
questions on http://www.starquestclub.com/forums/viewtopic.php?t=28095 I need to make some fuel lines for my MPI setup. I basically want a line that will go from the stock hard line into a universal fuel filter and then to the that same fitting that goes on into the stock manifold. Any creative cheap ideas? http://2.6liter.com/userfiles/StarPauser/FuelLines.jpg
How does everyone like there Megasquirt?
conquestpa replied to 87quest-TSI's topic in MPI/Standalone Trials and Tribulations
The megasquirt is very cool. You'll find out much more about at MSEFI.com and the tech forums. I lurk in those forums frequently from time to time as well. I love it so far. I need to get my clutch in, do some brake and front end work and then I'll be able to start tuning it and get it inspected and back on the road. Im running MS with a Magna modified intake, Ford EDIS ignition. I still have to upgrade my fuel pump and some lines, but Im very happy with it so far. It sounds really mean. I can't wait to get it on the road. For the price its the best standalone money can buy. Its also a great learning expirence. -
Stock Injector Megasquirt Constants
conquestpa replied to ZeroKewl9's topic in MPI/Standalone Trials and Tribulations
HOw are your duty cycles looking? It would really be helpful to have specs on these injectors... Im sure there around somewhere. I would think with TPI you would run the one injector on one of the injector output banks and one on the other. There is modified megasquirt firmware / coding out there the you could set it up for sequitial injection, but I think you have a pretty good setup there. -
If you have a wide band O2 sensor do you still need a EGT sensor? Or can WB02 usually do EGT? :?:
Almost ready to install
conquestpa replied to conquestpa's topic in MPI/Standalone Trials and Tribulations
new pics degicank.com/quest/wires/ -
What Fuel pump and pressure are you running? How is your ignition timing setup? I wonder how much your intercooler helps.
I love it, even though I can't really drive it yet... I'm putting in a new clutch soon, and doing some brake work. The clutch slips so bad right now. Then Im sending it out for inspection... :twisted: I can tell it has so much more power now... It really screams now. And I have a bad crimp in my intercooler pipes that I have to work out. I also don't have a laptop to tune it with yet... -
It runs! Got it running last night.... -
Megasquirt-n-EDIS Running :)
conquestpa replied to eeaston's topic in MPI/Standalone Trials and Tribulations
Got it running!!~ -
Here's a pic of an elise I saw last week... http://degicank.com/quest/lotus.JPG
Didn't get it running yesterday, barely got the VR sensor test mounted, and started attaching the crank wheel to the pulley.... Im going to finishing mounting up the 36-1 wheel today. Hopefully if everything goes well today Ill be wiring the EDIS up and then firing it up.
