jeremiahsux
    2
Everything posted by jeremiahsux
  1. update: i got a set from steve. thanks all
  2. Hi all, looking for two 850cc injectors for my starion. Cleaning has been attempted twice, they keep getting jammed up. Not sure if its age or what, but im also going to be replacing my entire hardline to the pump.
  3. im currently trying as well, I have it now i just have to convert all the html files and such into jpgs. will be much easier to sort through
  4. Both injectors ended up being stuck closed! Shoutouts to psu_crash for helping me out !!
  5. poured gas directly into the tb when I got it to fire off.. I think some of the residual stuff was just sitting in the intake when I got it to shoot off with the key.
  6. Hi everyone, It feels like i'm chasing my tail with this issue, and I wanted to document it and ask for all of your help. The car ran when parked 6 months ago... full tank of fresh gas new fuel pump. only changed out the turbocharger for a good one, and when I went to start it, cranking but no fire! 1985 Flatty LS model. I checked all the in cabin fuses and they are all fine.. I swapped out the ecu and had no change. I hear my relays clicking inside the car and fuel pump works while cranking as well. I have tried jumpering the fuel pump, it runs and I hear fuel flowing to my injs but they are not spraying. It will start on starting fluid. I have spark, I watched a spark plug grounded to the valve cover sparking great. Tach is bouncing slightly when cranking inside car as well. I have replaced several grounds and cleaned up corrosion, and also replaced the injector clips and sanded the injectors connectors clean. Injectors both tested good at 3ohm, and i'm getting 12 volts to injectors. I am not sure if it could be a short somewhere.. if not.. where else to start looking... any advice or pointers would be great. I've looked at almost every post related on the forum. Thanks all
  7. Hi all, I am looking for an ECU for my 1985 flatty starion... Model number MD096214 E2T13483 5425
