wave5000
Newbies
Everything posted by wave5000
  1. Ok so my concern is safety, are starion seatbelts centrifugal type or pendulum type how do I know if they work or not? thanks. my car is 6/86 production date.
  2. How do seatbelts work with these cars? I pulled it fast but it does not stop like it should are they bad?(I have the lap belt and auto slide in the door side not working) Thanks .
  3. Ok thanks for all the replies so that is where the ground is!!! I have been looking for that thanks will clean and reattach the ground screws..
  4. Hi 93gsx I did the thermosensor wire mod and not the relay wire mod they are the same right?I will try relay also will update you after thanks.
  5. Hi yes that a/c fan I followed PQs mod in xi site and he said this mod will trigger pusher fan also.Is this a bad relay or can anybody show wiring diagram thanks.
  6. Hi new member here I have 86 starion esir(6/86 prod date). I wired the primary and secondary radiator fan to come on same time and those work fine . Will the pusher fan work with his mod?Tested the pusher fan wires and there is 12volt power when triggered but it is a weak negative signal notenough to spin the fan. Fan works fine when 12v is applied direcly. Thnks to all great site here and did all my fixes using this site.
