SunStreaker
Cybertron
60622
SunStreaker's Achievements
I know, I currently have an engine with a spun bearing and there isnt as much metal in this one as the spun one.
Indian I did line up the rings for the picture. And detonation seems like a very good explanation because the previous owner of the engine has fuel issues that he said resulted of a kinked fuel hose. So to repair detonation damage, rehone shuffle the pistons? I also found a little copper fragment very tiny in the oil pan, and there was metal in the oil. The metal in the oil was very small like sparkles, probably from the pistons or the cylinder wall?
Took it apart and lined up s*** to take pics I don't know what irregularity is supposed to look like http://i.imgur.com/lt8ja.jpg http://i.imgur.com/31mjS.jpg http://i.imgur.com/ORDoa.jpg http://i.imgur.com/N59nw.jpg http://i.imgur.com/7EBRL.jpg http://i.imgur.com/P2zPl.jpg http://i.imgur.com/9cwv0.jpg
If this is the problem what would the solution be?
Can I just pull 1 piston?
It seems like there is more contact in that area resulting in a polished surface. Can I pull just that one piston? What else would I need to do? The compression was fine across all cylinders.
Its not from the rings being aligned the same way with a gap because its smoother on that strip its almost like a mirror like polish up and down. No carbon build up just more polished than the rest like more contact or wear? And the engine was rebuilt, no carbon buildup anywhere. Everything is new and clean.
It looks like its from the piston traveling up and down, should I be worried about it? http://i.imgur.com/VlJBO.jpg http://i.imgur.com/WhtKQ.jpg http://i.imgur.com/copUS.jpg
2 4G64 wideblocks in Nashville Pull-a-part
SunStreaker replied to MainstreaM's topic in Parts for sale
I like to use car-part.com it looks in junkyards across the USA gives you mileage and even condition of the part or block. There are several 4g64's listed and even found 3.90 ratios for as low as 50 bucks. I suggest you guys check it out real useful tool. -
Dumb Question on Jet Valve Elimination Kit...
SunStreaker replied to 83Starion-11's topic in Just plain ol' B.S.
I had a set of Jet Valve Eliminators and I had a cracked head, but my head cracked between the valves barely visible and on the #2 cylinder. It did overheat because of a blowhead gasket. The jet valves arent terrible themselves but they tend to fail, WHY because people dont maintain them or inspect them which should be done. People are not used to their upkeep so when they fail they blame them even though no maintenance was done to keep them running. Some people do it because they wanna eliminate that maintenance. -
3.1 rd time north west Indiana, Michigan Illinois and others
SunStreaker replied to wrngwae's topic in StarQuest Meet Planner
Im picking up my engine tomorrow in bensenville and the work begins. I have all day tomorrow from 4 to work on it and after school each day and all of friday. I should be done! -
How do I unbolt the tc?
I have looked through the FSM and have a few questions. I wanna pull the motor without the auto trans not to fumble with the switches and wires and stuff. Do I just need to unbolt the bellhousing and pull the engine forward a bit to clear the input shaft and then its fine to remove or is the flywheel attached to the torque converter in some way? I also have a clutch fan does the radiator need to be removed to clear the fan or just the shroud? Any tips or tricks?
Dads machine shop
