skylinetwo40
About skylinetwo40
  • Birthday 11/05/1978
    Vancouver WA
skylinetwo40's Achievements
  1. I have an 88' TSI for sale minimal shaft play on the turbo lsd rear end Black leather seats motor runs real strong the auto trans has a bad torque converter $700 located in Vancouver WA. Will ship at buyers expense
  2. here it is on CL http://portland.craigslist.org/search/cta?...&maxAsk=max
  3. yeah I decided to go ahead and start from scratch gonna do it tomarrow. thanks for the info.
  4. I can put it in park and that works fine its just the "moving" gears
  5. I didn't pull the whole distributer out. I just slid the little wings out about a half inchthen pushed it straight back in.
  6. I pulled it out about 1/2 of an inch.
  7. I moved my car the other day and parked it then I went out to move it last night and it wont move.. It's an 88' auto. I've tried putting it in every gear and it won't budge. It's almost like it's in Neutral in every gear. (I can push it)
  8. I have an 88' auto. I just changed my vac. advance and had to pull the wings with the springs in the dist. out about a half inch to be able to get it unhooked. Now my problem is its not firing right . I got it to start once but it ran worse than when I replaced the vac. advance. Could I have possibly screwed up the timing? And if so How do I adjust it?
  9. well there are no cats. and I checked the vac advance it didn't seem like it changed much when I unplugged the vac line. so I'm thinking it's bad.
  10. I'm having trouble with the idle and acceleration. It takes a while to warm up but when it does it idles around 500-750 rpm. Once it's warmed up I can get it to rev between 4500-5000 but when it hits 5k it starts to studder and pop almost like theres a blockage or something. Any help would be greatly appreciated..
  11. whats the 1G DSM off of? and whats the GM MAF-T off of?
  12. I have an 88' TSI auto is there any way to get rid of or shrink the MAS? Is there a different one I can use?
  13. It was the ignitor box. She fired right up. had to replace the exhaust manifold gasket tho had one spot that was completely blown out. And to top it off I broke to studs after soaking threads for a couple of days. Then broke an easy out ta boot. But all back together now and running. Still have some fine tuning to do. It does have some hesitation and a bit of a rough idle but it's getting there. Thanks for all the info
