Everything posted by Kenny G
check your fusible links and grounds. also check/swap your ECI control relay under the right kick panel above the ECU.
my problem was with the knock box on my 87. I just upgraded it with an 88 ignition box, just kept the connector and wired it up. works great!
text me at 7572910157 im about to scape my parts car. send a pic of what you need
I have a parts car that's an 88, I'm sure this is what you need but I also had an 87 an don't know if they are interchangeable. not sure on the part numbers that I have.
yes, I know they are very hard to find. is the caliper different on an 87? do you know the part number? lmk text me at 757-291-0157
I have some but need work with clear coat. text me at 757-291-0157 for pics. cheap $35 each plus shipping.
i need rear limit switch that turns on rear inside dome light
Kenny G replied to chrisbrasher25's topic in Items Wanted
I have one ready to go. text me the picture to verify the part. I that's it I will sell for $10 to you plus shipping. -
my 87 knock box died and left me stranded. hard to find a 87 and below, but I was told to get about 6" from a harness of 88-89 igniter box and use that box instead as they more reliable. I did and just left off the 2 extra wires off, all others are color coded the same and it fired right up! Good luck finding one. I got a broke one if you want it!
Don't forget to replace your foam seals before install your tail lights, this will prevent water infiltration thus prevent the corrosion in the future. Make them from 1/4" foam using the old ones as a pattern. I'm still looking for the sockets then I can text or email pics to you. PM your info to me and ill do it this weekend.
I have them both let me put my hands on them and I'll let you know. Pm me by the weekend if you don't hear from me if you still need them.
I got a set last year, I still have some and the box it shipped in. I will check when I get home and let you know who I got them from.
Have you tried replacing the drive belts on yours yet? very hard to find one that works after 25 years. I did mine and it works fine now.
the shield looks like a round drink cup on the end of you trans. if your drive shaft is installed on the trans, you will see part of the input shaft from your u joint end (if your shield is NOT installed). If you can't see the shaft and the shield will cover it up to the u joint. I hope this helps.
while on jacks, check to make sure your forward drive shaft u joint in not rubbing on the back of your transmission output shaft shield. it will make a very loud grinding sound. I found mine out of round and could not straighten it so I just removed it from the back of the tranny. it's only pressed on the end and can easily be removed. good searching!
it could be your ecu. however, I was driving mine down the interstate and mine would shut down as if you turned the key off. after many hours of troubleshooting I found only the distributor and igniter box left it could be. and yes, I did change the ecu and it didn't help. I changed the igniter box out and it started right up! good luck with your issue... stick with it, you will get it!
I have one in black already removed. text me at 757-291-0157 if interested and I'll send pics.
Sorry Mike... I sold mine 3 months ago. I think everybody refers the as a Header Panel. whoever you get one from, make sure it's well packed... these get damaged easily or recommend buying it locally. Kenny
Wanted: Front Windshield. As close as possible to Washington D.C.
Kenny G replied to vanillagorilla's topic in Items Wanted
I got mine from Glass Masters out of Richmond. They had it in 1 day. install $168 -
Trying to crank rebuild for first time...Wont stay idling
Kenny G replied to Preludedude's topic in Advanced Virtual Mechanic
injectors most likely. after rebuild mine... it ran really bad too. I replaced them and ran great. evidently from sitting for a year they will dry up and stick oper or closed.... mine was flooding out. It could be a simple vacuum leak too. -
oh ok... I'll pull them and take pics this weekend for you Nightcall. But I still think maybe you 87 was built 6/87 and and below and maybe that's why it worked for you. My donar car is an 88.
just looked up parts for your locks. different part no#'s from 6/87 and below for ignition and trunk. sorry. mine will not work for you.
Ill have to pull them off my spare parts car. but PM me as to what you want? like IE... ignition, door, too... as well as the glove trunk gas door? price and shipping? I don't know whats a fair price? text me 757-291-0157. Kenny
I got both. I will have to pull it off my parts car. PM me if interested and shipping info
thanks Dad, I will still take one if u get it.
