Everything posted by hippynerd
I like flat black. it hides the dirt, but you can stil find oil leaks when they happen.
The quick easy way would be to just replace the switch. You could repaire it to factory, assuming the wiring, relays, sensors all work, and if you only have to replace a sensor to get it to work, then its not too bad, but you may have to study chapter 8 a lot, and test each compnent and trace every wire. It may not be hard to fix, or it may take days, hard to say from here. Another option is to replace the elelctric fans with a clutch fan and shroud. Its more reliable, and lightens the load on the electrical system quite a lot.
Looking for a turbo online to fit stock 8cm exhaust manifold
hippynerd replied to TSIREX's topic in Just plain ol' B.S.
Heh, no, i used a drill, many grinding bits, and a fetl tip marker. I marked the housing where the parts mate with felt tip pen. Fit parts and scratch a little ink, and grind away where parts touch. Then I mark it up again with the pen where Ive ground it. I repeated the process about 100 times, it took all day. -
It took me all day, but I ground my td05 to td05h, and now lots of cartridges will fit. I have another, I should have it machined to td06 -
Somehow I managed to melt the insides of the second cat. It was seriously preventing the car from boosting, but the engine still ran ok. I also blew apart a turbo (14b). When i took the turbo off the car, It blew the oil ring into the turbine housing, and the nut was half unscrewed of the spindle. Here is a timelapse of dissassembly, and re-assembly. The turbo will work, but its been damaged enough that it wont work well. It needs a rebuild, with new bearings and wheels.
From the album: weirdness
LEDs are actually much lower voltage that 12v. You have to use resistors, or current limiting circuits to prevent burning them up. Stuff that is marketted for cars are usually set up for 12v, so all you have to do is hook it up right.
Update: I had some wiring problems and my door lights shorted out, and took some fuses with it. I went through the electronics, and cleaned stuff up, and replaced fuses and door locks, windows, and remote start all work right again. I need to lube the passenger side window tracks and stuff so that it rolls up like the drivers side, because it rolls too slow, and the window doesnt go up all the way with the remote. This car is way faster than my car, and a lot of fun. I will miss it.
Hey, 2 months ago, I had 2 non-running cars pissing me off.
I fetched a hopefully good transmission, and a new bumper cover the other day, and I've looked at the transmission, and cleaned up the pan gasket, and re-sealed it. It looks good inside, so hopefully everything is OK with it. I took my 83 transmission out yesterday, and I have it ready to remove the 86 specific parts to put on the hopefully good transmission, then I will install it today. If things go well, I'll get some paint on the bumper cover, and may even get it installed, but Ill be happy to just get the trans done today.
Ive been working on the TPS/ISC and I cant seem to get the idle adjusted right, and both of the TPSs ive been using seem a ltittle bit erratic. The throttle gets kind of weird, it doesnt hold the same speed, you constantly have to lift and press a tiny amount to keep the car going the same speed. Ive also found that the car idles weird as it warms up. Often after the car warms up, the idle says too high (like 1500 rpm), but not always, sometimes it flattens out to like 800. It holds at 800 while warming up most of the time too. The most annoying problem is that it loses power. You will be driving along, and the car starts slowing down, you press on the gas, and the car slows down more, you press all the way down, and it continues to slow down. Sometime when this happens, pressing all the way down makes it cough and sputter, then runs ok, sometimes it just keeps slowing down. If I shut the motor off, wait for the motor to spin down, then start it, the problem goes away for a while, but always returns later. I think disconnecting the maf makes it go away, and disconnecting the ISC probably makes the idle thing go away.
I just got done installing remote start/lock/windows on my starion. It was a major pain in the butt, and took me days to complete. Door locks are easy, windows a little big more difficult, and remote start is a lot of stuff, if you have a manual transmission and or diesel. I used a setup from black widow, they have a unit that works with manual transmissions, and I found it on online fairly cheap. There is another company that seems to be much more popular with the install guys, I think they like DEI products. Things like range, automatic/manual transmission, gas/diesel extra outputs, are factors that may be important when choosing the right device for your application.
Im in eugene. I have a running starion.
300 Ohms is also the spec for my 83, it uses a different sender, but warmed up is about 300 ohms. Ive been trying to replace it for like 10 years. I finally found one, ordered it, but it doesnt work right, its like 10k ohms warmed up, and like 20k cold. What I did was hook up resistors, and when I had 100 ohms hooked up after the car was warm, it did not run right. I added a couple more 100 ohm resistors, and it smoothed out to a normal idle. I looked it up like 10 times in the 1986 manual online. Each time it says 104 ohms. I ended up using a new CTS that I had but didnt measure 100 ohms when heated on a pot in the kitchen. I spent about an hour and tested all the coolant sensors and measured them at 3 stages, cold (about 60 degrees), warmed up to the first mark on the gauge, and the last was over the second mark (fully warmed up) You can hear the engine change as the needle gets to those 2 lower marks on the gauge. The car seems to run like a normal car, and does the normal warm up routine. I dont really warm the car up, I start the motor, wait for oil pressure, then drive slowly the first couple blocks. Because of where I currently live, that means mostly idling downhill and sitting at a stop light. There are some electrical add ons, and some cosmetic things, then I think I will try to sell it. Right now it has the 16g turbo, I may experiment with the 14b turbo. Its been a ridiculous amount of work, and it would be nice to break even. I may even sell the car with no motor, this motor is from my car, and it can go right back in if it has too. I also have a mostly rebuilt 83 motor, but its probably going to need boring and pistons, rods, and rings. I wish I could keep them all, but I dont have space or money for them all. this one is way faster than my 83, but I still like my crusty old 83 better.
I didnt find the ISC stuff in the manual, but I did find stuff at starquest.i-x website. It turned out that my spare one the button didnt work. I took it apart, and was able to trouble shoot it down to corrosion on the contacts inside the thing. After putting it back together it wouldnt budge on the 6v battery that I had, so I ended up using the 12v. It didnt want to move at first, but after I exercised it a few times, it was back to working like it should. It turned out that the one that I thought was the spare, was the one from this car. I took the ICS off and change the throttle cable lever and parts for the longer ICS (the one that was originally on the car), and got it all working. The error code went a way! Yay! I did another TPS/ISC reset (I had to do it a couple times because I screwed things up.) I burned my hand a bit trying to adjust the idle screw. thats a pain in the butt. I think I got it set, I dont like the TPS though, its not very consistent. It works though, and its good enough till I figure out how to unbreak the original one. Yeah, its neat how the ICS works, you screw it all the way down, and that pushes a black plastic thing to push a copper tab up, to make the contacts contact. Then the switch at the tip will work.
I worked on the ISC again yesterday. I can confirm that my ISC seems to be working fine, but I still get 6 blinking lights. I tested the switch while it was in place, and its working, then I ran the motor both ways by hooking it up to the battery. It all seems fine. I took apart my spare ISC to see how it all works, and came up with simple test procedure. I didnt get a mechanical temp gauge hooked up, but I did test the CTS after the engine had warmed up (when the temp gauge goes past the 2nd mark on the gauge) You can hear the engine speed change a couple times, it seems to re-adjust the idle right about where the marks are on the gauge. The engine runs really crappy after it warms up, but then you shut the engine off, and start it up again, it runs real good for a while, then runs poorly again. The CTS (for the ECU) seems to be running about 400 ohms at temp (Im guessing thats about 160 degrees) The manual says that it should be at 104 ohms. When I tested that sensor, I put it in boiling water, and it read over 200 ohms. When the car gets up to temp, and isnt moving, the throttle goes up and down from 1000-1500 or so and wont drop down to regular idle speed. It stays at idle speed just fine untill the engine warms up, which seems kind of the opposite of what you might expect. I dont have the AC temp sensor hooked up, I wonder if that has anything to do with it?
I fussed around with the 2 ISCs that I have trying to figure out if I can use the long one, but I ended up breaking more wires and repairing them, and I just put the one that fits right back in the car. It seems to work, but there is a problem. When you start the car, it throws the code for ISC, and the ISC runs the throttle up and down about 500 RPMs over idle speed. It seems like it stops after like 5 minutes of idling. It throws the 1 blink code at first, but that goes away after the engine warms up a bit. I think that the brand new CTS isnt right. It didnt measure what the book said. I have the exact same problem on the 83, its OLD CTS droppped the lower threshold and doesnt work until the motor warms up, the new replacement CTS (very hard to part), measures way off what the spec is. My guess is that the maf is fine (although it probably wont handle the higher boost levels very well, its not failing) I also did the TPS/ISC reset. the TPS is a little bit janky, I dont get exactly the same voltage when I snap the throttle plate each time. its within a .02v of where I set it, but it bothers me that I dont get the exact same results each time. I think that I will work on temp gauge, mabye setup a mechanical gauge, and meter the sensors at various temps. The car is getting real close to be stable, and I plan on selling it when I get things working well. I may sell the car with extra parts like fenders and hood, and even my 83 motor thats half rebuilt, but needs more rebuilding. I think I want a diesel in my 83.
