burny kruger Posted August 22, 2009 Report Share Posted August 22, 2009 when i drove my car and gave it some gas it felt as if some of the power was not being delivered, finally when i got home it gave out completly, it reved well but in gear it would only rev and it would barley do 5mph lol, wt...., anyways, i think it might be the clutch, but i dont know what a bad clutch feels like.. any ideas??? kev Link to comment Share on other sites More sharing options...
89Steve Posted August 22, 2009 Report Share Posted August 22, 2009 Is it difficult to get the car into gear? 5-speed I assume? Link to comment Share on other sites More sharing options...
Indiana Posted August 22, 2009 Report Share Posted August 22, 2009 Well a burned up clutch will do that. Might also be a good clutch that has oil all over it too. Either way it have to come out and be replaced or cleaned. Link to comment Share on other sites More sharing options...
mikec Posted August 23, 2009 Report Share Posted August 23, 2009 Background: The clutch disk is "sandwiched" between the engine flywheel and the clutch pressure plate which is a series of finger-springs and a ring of beefy metal. Those springs push the beefy metal into one side of the clutch disk; the other side of the clutch disk is pushed against the engine flywheel and is "clamped" to transfer the power. The tranny is driven by the clutch disk. So, to get power from the engine through the clutch to the tranny, the clamping grip has to be solid. When you push on the clutch pedal to shift, what happens is the "throwout bearing" (moved by the clutch pedal hydraulics) pushes on those finger springs to flex them, releasing the clamping force. A cltuch that's almost worn out "slips" in 5th and 4th gears as you mash the gas... you'll see the engine RPMs go up but the MPH won't go up to match. That normally happens when the friction material of the clutch disk is worn to the limits - the disk isn't thick enough to be properly clamped/squeezed by the flywheel and the beefy metal ring. Those finger-springs, the beefy metal ring, and the thickness of the clutch disk when worn are all sized/designed to not grip fully when the clutch disk is thin - so the driver feels the clutch slip and knows something is wrong - time for a clutch job. If the driver ignores the slippage, the clutch will continue to wear out (faster and faster thanks to the slippage) until the tranny slips in 3rd gear, then 2nd, etc. Evenually though the friction material on the clutch disk will be so thin that the rivets that hold it to the disk body get exposed... those rivets will grind grooves into the flywheel which can destroy it. It takes a LOT of machining to flatten it out again. As Indiana noted, if the clutch disk gets contaminated with oil or other slippery crap, well... it isn't gonna hold under any clamping force. A clutch pedal hydraulic assembly that is incorrectly adjusted will also lead to a slipping clutch. With the engine off, use your pinky finger to press the clutch pedal. It should move at least a quarter inch, preferably nearly half an inch, with almost no effort. If it's stiff right away, the pedal freeplay is too low and it's like you're driving with your foot pushing the pedal down a bit... preventing the hydraulics from releasing fully. No wonder it's slipping and wearing. Follow the clutch pedal arm under the dash, you'll see where it hooks to a yellow/gold colored rod and jam nut assembly. Loosen the nut (you'll need 2 wrenches: one on the nut, one on a nut-shaped part of the big gold cylinder you'll see) and spin the nut free a few turns. The threaded portion of that assembly then screws in/out of the gold canister to adjust the freeplay. Once it's correct, re-tighten the jam nut to lock the threaded shaft in place. Ever see brake rotors that have blue streak heat damage from somebody "riding the brakes" on a long downhill or from some other issue that overheated the brakes? That same type of damage happens to the flywheel when the clutch disk slips - lots of heat gets formed. If the flywheel is blue streaked, it may have to be replaced. A machine shop that does flywheel surfacing will be able to tell you. Other ideas for your bug: if the engine RPMs go up, and the dash speedometer reads higher MPH than the car seems to be going, it's not the clutch. The output of the tranny is turning fast (thus the high dash MPH since it measures speed at the tranny output) but the power isn't getting to the wheels. That would mean any/all of the following: * worn out "torque tube" assembly. This is the part that connects the drive shaft to the differential. It has a pair of gear-like fittings that can grind away and slip if they don't get greased once in a while. * axle joints (commonly known as "CV joints") bad. The "input" end (from the differential) is spinning but the energy doesn't go through the joint to turn the wheels/tires. If the rubber boots on the "half shafts" (the short driveshaft like pieces going from the differential to the rear wheels) are split/torn at all, you can bet the joint inside that boot is trashed. Rebulid or replace. mike c. Link to comment Share on other sites More sharing options...
Piggylover1985 Posted August 24, 2009 Report Share Posted August 24, 2009 sound like bad clutch, how old is the clutch ? my stealth was doing the samething, when hot the engine rev really high but the car is barely moving, but i just put a new clutch in ita few weeks ago, i replaced the slave also, but found out it was the clutch master cylinder is junk. Link to comment Share on other sites More sharing options...
Killtodie Posted August 24, 2009 Report Share Posted August 24, 2009 from a stand still when you put it in 5th gear and let out on the clutch, does the car stall immediately or does it lunge forward? Link to comment Share on other sites More sharing options...
burny kruger Posted August 24, 2009 Author Report Share Posted August 24, 2009 clutch gave a small amount of play with the pinky finger test, i started it up and put it in first and it wanted to go for a sec and the n just reved,,, i gut it in 5th and let the clutch out and it keept running like it was in nutural,,, Link to comment Share on other sites More sharing options...
mikec Posted August 25, 2009 Report Share Posted August 25, 2009 clutch gave a small amount of play with the pinky finger test, i started it up and put it in first and it wanted to go for a sec and the n just reved,,, i gut it in 5th and let the clutch out and it keept running like it was in nutural,,, Sounds like a totally worn out clutch. When you did this 5th gear test... what did the speedometer read? If zero, it's the clutch. If not zero, it's driveline/torque tube. mike c. Link to comment Share on other sites More sharing options...
burny kruger Posted August 25, 2009 Author Report Share Posted August 25, 2009 yup absolut zero.... damn,,, has anyone heard of exedy? are they ok? i dynoed 203 rwhp and 258 tq. Link to comment Share on other sites More sharing options...
