substock Posted November 9, 2006 Report Share Posted November 9, 2006 while i'm building all of my braided lines, i'm going to get an aftermarket fuel filter also. what would be a good one to buy? my line is -6an, after looking through some i noticed max psi for them, what is a good max psi? i saw that Indiana is using this one:http://store.summitracing.com/partdetail.a...mp;autoview=sku it is 75max psi, will that be enough? i found a a russel performance filter(that is almost identical to the earl's above), on ebay brand new for a cheap amount. it is also 75psi, if that is enough i may bid on it also, what is a good adj. fuel pressure reg? i notice a lot of people using the aeromotives, which one would be the right one to buy? Link to comment Share on other sites More sharing options...
emagdnim Posted November 9, 2006 Report Share Posted November 9, 2006 You will not go wrong with a stock filter and Two straight Metric to -6AN fitting's. :wink: Link to comment Share on other sites More sharing options...
Starcon88 Posted November 9, 2006 Report Share Posted November 9, 2006 The stocker is not bad depending on what fuel PSI you will be running. The reason John and I put it on my truck was to save room and because the Mopar injecters I have need at least 55PSI and that without any boost rising rate on it. Also come it looks kool 8) Link to comment Share on other sites More sharing options...
MontyTSI Posted November 9, 2006 Report Share Posted November 9, 2006 75 psi should be plenty, there is some built in over run on that and keeping in mind 95 percent of the time you will not be anywhere near that Link to comment Share on other sites More sharing options...
Starcon88 Posted November 9, 2006 Report Share Posted November 9, 2006 75 psi should be plenty, there is some built in over run on that and keeping in mind 95 percent of the time you will not be anywhere near that lol hey monty come on 95% lol i'm in my boost 95% Come on monty don't lie 8) Link to comment Share on other sites More sharing options...
Indiana Posted November 9, 2006 Report Share Posted November 9, 2006 I forget but that filter with the stainless screen wire had holes so big sand would pass through and there was a cartridge that went inside of it and we didn't show that part you want this one http://store.summitracing.com/partdetail.a...mp;autoview=sku not that other one ******Maximum filtration for fuel systems.These Earl's in-line fuel filters provide maximum protection for fuel systems. They're available in your choice of a screen filter or a sintered bronze element. Either unit can be easily disassembled for inspection and cleaning. The filter housings are available with size -6 AN, -8 AN, or hose barb ends (bronze element only) for use with Earl's high-performance fuel line and fittings. They have a fuel flow of 4 to 5 gpm, and come in a nice blue anodized finish. Link to comment Share on other sites More sharing options...
tux Posted November 9, 2006 Report Share Posted November 9, 2006 oh cute, the cheaper on is better ? Link to comment Share on other sites More sharing options...
MontyTSI Posted November 9, 2006 Report Share Posted November 9, 2006 75 psi should be plenty, there is some built in over run on that and keeping in mind 95 percent of the time you will not be anywhere near that lol hey monty come on 95% lol i'm in my boost 95% Come on monty don't lie 8) thats because you are the lead footed bandit !!! Link to comment Share on other sites More sharing options...
substock Posted November 9, 2006 Author Report Share Posted November 9, 2006 thanks guys, i have some thinking to do. i may just keep with the stock filter for the moment and do another one at a later time Link to comment Share on other sites More sharing options...
DJpowerHaus Posted November 13, 2006 Report Share Posted November 13, 2006 That first one had a 85 micron filter element while the 2nd had a 35 micron filter. In my opinion both are not near fine enough. Most injectors need the fuel filtered to 10 microns in order to not clog up over time. Link to comment Share on other sites More sharing options...
83TechMaster Posted November 14, 2006 Report Share Posted November 14, 2006 i have this one and like it very much Competition Inline Filter 10210 http://www.professional-products.com/inlinefilters.html http://www.26liter.us/gallery/albums/userpics/10102/DSCF0001.JPG Link to comment Share on other sites More sharing options...
tux Posted November 14, 2006 Report Share Posted November 14, 2006 i have this one and like it very much Competition Inline Filter 10210 http://www.professional-products.com/inlinefilters.html The Competition Inline Filter is designed for racing applications using gasoline or alcohol on carbureted. Link to comment Share on other sites More sharing options...
artinist Posted November 14, 2006 Report Share Posted November 14, 2006 those earls filters are rated at just 75 psi max, i think they are rated for carb use or some other lower pressure system. i think this is a pretty good one. i like this because it already comes with male fitting ends. http://store.summitracing.com/partdetail.a...mp;autoview=sku Link to comment Share on other sites More sharing options...
