rigger Posted February 2, 2006 Report Share Posted February 2, 2006 Any one else thought oabout this lovely VOLVO powerplant, or am I the only crazy one??? I figure it will take me about 7 years to get my swap done ... but by golly I am going to do it!!!!! Only problem Is I will have to wreck a nice volvo to get the darn engine. But then i guess I could put the seats in too!!!! :shock: :shock: :shock: :shock: P.S. this is only partialy a joke..... I might actualy do this If i can find a donor car for the right price. Some european guys are pushing 8-900hp out of these things..... and they have a SWEET torque curve. Crump Link to comment Share on other sites More sharing options...
smog Posted February 3, 2006 Report Share Posted February 3, 2006 is thatt eh 2.3l dohc inline 5? If so,m sweet engine. Link to comment Share on other sites More sharing options...
Guest Posted February 3, 2006 Report Share Posted February 3, 2006 That would be one hell of a swap. Should sound really neat as well. I hope you go through with it! Link to comment Share on other sites More sharing options...
rigger Posted February 3, 2006 Author Report Share Posted February 3, 2006 Actualy it is the twin turbo I6 they put in the S80 and XC90 (befor they went with the V8) but the thing is only pushing 5 psi and putting down Horsepower 268@5200 RPMTorque 280@1800-5,800 RPM stock!!!!! Low friction all aloy block and some other niceness.... did i tell you about the Frigging seats?? they go back to where you had them when you use your clicker ( handy when your wife is 5'5 and youy are 6'1) and they have heaters in the seats( useless out here in hawaii though)... Man do i love volvo!!1!!!!! too bad they are now owned by ford. Crump Link to comment Share on other sites More sharing options...
smog Posted February 3, 2006 Report Share Posted February 3, 2006 Sounds like it would make a killer engine swap. These newer volvo inlines are fawking bad a**. Link to comment Share on other sites More sharing options...
rigger Posted February 3, 2006 Author Report Share Posted February 3, 2006 Yes they are but now I am looking at the weight issue and maybe the 2.5 5 cyl might be a better Idea..... got to find measurements for both engines and see where in the engine bay they would have to sit...... push back the firewall and all of that..... I started this out as ajokeing Idea but now i am really interested. Only down side is that Volvo aint exactly cheap... so not really a cost effective swap.... then again they last a good while. Any one has any of the dimentional info for these engines? I am measureing the wifes S80 seats tonight...... maybe they will fit... Bu ha ha ha. Crump Link to comment Share on other sites More sharing options...
Guest Posted February 3, 2006 Report Share Posted February 3, 2006 Yes they are but now I am looking at the weight issue and maybe the 2.5 5 cyl might be a better Idea..... got to find measurements for both engines and see where in the engine bay they would have to sit...... push back the firewall and all of that..... I started this out as ajokeing Idea but now i am really interested. Only down side is that Volvo aint exactly cheap... so not really a cost effective swap.... then again they last a good while. Any one has any of the dimentional info for these engines? I am measureing the wifes S80 seats tonight...... maybe they will fit... Bu ha ha ha. Crump Neither is the sr20 swap, but this swap would be far more interesting. The line 5 is just interesting. Link to comment Share on other sites More sharing options...
rigger Posted February 3, 2006 Author Report Share Posted February 3, 2006 I know now Ai think I am going to go knocking on doors asking for donations to do this swap. Knock Knock Knock...... any one want to be the first to donate. Crump Link to comment Share on other sites More sharing options...
Technology Posted February 3, 2006 Report Share Posted February 3, 2006 Low friction all aloy block and some other niceness....Crump come on meow. low friction? my block is low friction. i use 15w40 motor oil to achieve the new hotness. how many liters? Link to comment Share on other sites More sharing options...
smog Posted February 4, 2006 Report Share Posted February 4, 2006 weight my butt, if its an alloy block, its lighter than my 1jz, although my 1jz cost less than a sr20det or that engine The expense of parts and what not is the only big downside going with a volvo engine. Link to comment Share on other sites More sharing options...
rigger Posted February 4, 2006 Author Report Share Posted February 4, 2006 How about "Lower" friction engine........ exerpt from.. http://www.volvocars.com.my/FinancialServices/Fleet/Use.htm Improving engine efficiencyFriction occurs in all engines due to contact between the various components, resulting in energy losses. Methods of lowering friction include reducing the mass of the valves and modifying valve operation. In a conventional engine, the camshaft opens and closes the valves at the same regular intervals, regardless of how the car is being driven. However, the initial position of the camshaft can be varied by sensing electronically how the driver wishes to drive the car, resulting in optimum efficiency in each individual situation. Variable valve control is nothing new. However, Volvo Cars has refined the technology to produce CVVT (Continuously Variable Valve Technology), which reduces fuel consumption and exhaust emissions when idling and when driving at normal speeds on the open road. More aggressive driving increases engine output. A third method is to reduce the resistance to ventilation of the engine crankcase gases, while a fourth is to lengthen the connecting rods to reduce the friction between the pistons and cylinder walls. Finally, energy losses can be reduced by using lighter moving parts. Making the crankshaft and pistons smaller also reduces engine weight and friction losses.> either way cant complain about the power and gas milage. The wifes S80 with the 2.9 N/A engine gets roughly 25-30 MPG in town...... and that is their biggest sedan......( of course it is probably only 300 pounds more than my fat girls but hey). any way they have newer Tech than us, so I won't complain :shock: :shock: :shock: Link to comment Share on other sites More sharing options...
rigger Posted February 4, 2006 Author Report Share Posted February 4, 2006 This is kind of cool to think about.... non turbo, but I love enginuitave solutions to problems. If they turbo this thing i might just order one form the maunfaturer. http://wheels.fosfor.se/new-six-cylinder-engine-from-volvo/ Link to comment Share on other sites More sharing options...
Guest Posted February 8, 2006 Report Share Posted February 8, 2006 http://img.infotropic.com/w/w060201_1.jpg Look at all those damn flywheel bolts! Link to comment Share on other sites More sharing options...
Low White N Boosted Posted June 24, 2006 Report Share Posted June 24, 2006 f*** that, rb26 it. Link to comment Share on other sites More sharing options...
