dyno run on new MPI
http://home.comcast.net/~kevin_connell/mpi/dyno-mpi.jpg
Ported Head
Shawn Silva Header
Chad's Intake
65lb/hr racetronic injectors
megasquirt
19 psi boost
forced performance green turbo w/ TD06H
evo VIII intercoooler, 2.5" IC piping, ford 65mm TB
3" exhaust, including cat.
very very little ignition timing on pump gas.
Allright. You got a tad more mods than I do. lol.
I wonder how that thing pulls though going down the road. Must be fun. Are you all done tunning. Or are you going to get some more out of that thing. Adam :-)
walbro 255, 36psi base, msd-2222 regulator (1:1 BCFPR)
I'll post my timing tables today at some point in that earlier megasquirt tables thread.
It's tuned as much as possible for power, bleeding edge of timing and boost running around 12.5:1 AFR. I'll be tuning other areas for streetability, mainly acceleration bins and timing.
I may also be investigating nitrous and/or water injection for grins, but I really want to move on to the other neglected areas of the car, wheels, tires, suspension, brakes, and interior :roll:
Nice work!!! I just got mine up and running last night with the new ported head. I'm also running Chads intake and 75lb injectors. I made 294rwhp and 332 or 342rwtq @ 15psi with a blown headgasket @ 2 & 3. I now have the ported head and the resurfaced block and head so it will seal this time and will be back on the dyno aiming for atleast 20psi on pump and atleast 350 at the wheels!
The green was a sweet turbo for my dsm, I'd like to feel it on a starquest. My best and consistent times were 7.3@97 1/8 and 11.6@120 in the 1/4. That turbo usually doesn't die off like that on the other side of the track but it was shot and when I got into 4th the wheel would have big load on it and gaul up the housing and slow me down. Unfortunately after I had it "built" I sold it and parted the car. I wish I woudl've run it in the 1/4 when it was newer!
Kev, what cam are you running, hydro or mech, what lift/duration? Stock manifold modified for Eclipse turbo or new tubular or log style manifold? Internal or external wastegate? Just some things I'd like to know..
mech *DM cam, don't know the specs. shawn silva tubular header (note: Turbo is NOT a DSM, the starion exhaust housing bored out for TD06H, starion cartridge with td06 shaft) Internal wastegate, which is highly borderline, I did have boost creep but it seems to have subsided.
U run 12° timing at full boost?
I'd try to get the most from that turbo before playing with nitros. Or even water/aly to max out pump gas numbers.
must be a blast to drive. Very nice effort!
Very nice!!! You hold the "most power from a megasquirted 'quest" title, those numbers are absolutely great!
BTW, you should post this on the MSEFI site success stories, that's a lot of power from a 4-banger! :D
Very nice, Its nice to see a graph pulling past 6K! When I get Mine done I want it pulling over 300whp @ 6500rpm. By the way, Ive never seen a Megasquirt make power like that, I didnt think it would do it. Thanks for proving me wrong! Oh yeah, what Octane was that on?
heef - compression ratio is around 9:1, flat top custom wisecos, never measured it. near zero deck height. Wish I would have gone with dish, 8:1, think I could easily break 350 on pump gas with this turbo and lower CR.
Phinko- octane is 92. Get a non-magna intake, porting, header, and big cam if you want to make power up in the high-rpm range. The rev limiter on the MS is the only thing keeping my motor together, it revs to the moon. :twisted:
I'm amazed you can get run 92 octane with 19lbs of boost and 9:1 compression. What is your full boost timing set at?
Dave
Not just that but on a T4 60 Trim MHI hybrid!
That turbo he has ain't no off the shelf 05/06 20G.
I'm shocked too man!
