Chris.RO Posted December 14, 2004 Report Share Posted December 14, 2004 Hi.I have an '89 Starion WB 2.6 turbo intercooler and there's no diagn.conector under the glove box.On the '86 model (I have also one broken) is a blue con. under the box. Did somebody know error codes and connector for the '89?Sometime the engine rpm is falling down at idle for a few sec even if you step on.It's a bit dangereus when you try to overtake shortly.I can't solve this problem for a long time.Can be the knock sensor? Need some ideas!!!I am located in Romania(Europe) and have nobody to speak with about this car(5 in my country and 3 are mine). Link to comment Share on other sites More sharing options...
Edde Posted December 14, 2004 Report Share Posted December 14, 2004 If it's a US model it has to be there. Look again. If it has never been ripped out from it's holder it will really be between the top of the glovebox (when open) and the dash.. Link to comment Share on other sites More sharing options...
JAinsworth Posted December 14, 2004 Report Share Posted December 14, 2004 You will have to drop your glove box lid down to really see the connector. To drop the box, gently squeeze both side and lower it. Once it flips down, get upside down in the floorboard, and look up. It is towards the driver's side. (assuming the car in left hand drive) Jimmy Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted December 15, 2004 Report Share Posted December 15, 2004 In addition to what Jimmy said.. When I looked for mine, I noticed that the wiring for the connector in question was tied down to the glove box's surrounding frame using little bendable metal fingers(not on the box itself, but rather above it).. You'll see the frame when you get on your back and look up like Jimmy mentioned, the connector sits on top of this... Link to comment Share on other sites More sharing options...
Chris.RO Posted December 15, 2004 Report Share Posted December 15, 2004 - First of all it is EUROPEAN modelSTARION 2.6 ECI TURBO. -To identify the conector I need the complete wireing for this car,because for sure is not under the glove box(I changed interior two times and dash bord). -I also need this dyagram to trick the boost limit wich I understood is limit by ECU,and water sensor But first step I must check the error codes to see the O2 and other imp items.THANKS. Link to comment Share on other sites More sharing options...
soulassasincc Posted February 18, 2008 Report Share Posted February 18, 2008 i have an 86 i hooked up the led diagnostics light and i got a o2 sensor code... my sensor was trash... i replaced it pulled batt off to reset ecu and still it throws the code....donno what is up.. also my car runs too rich blact smoke comes out and black film too car sounds like a domestic Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted February 18, 2008 Report Share Posted February 18, 2008 The oxygen sensor code will always be shown until the motor and/or O2 sensor is fully warm. Running rich could be a function of staying in open loop all the time, or leaky injectors and/or FPR. Bad CTS(would throw code though).. Link to comment Share on other sites More sharing options...
soulassasincc Posted February 18, 2008 Report Share Posted February 18, 2008 wats fpr and cts..? well what does it do if the car is fine and there are no problems at all? is there a all go code? lol Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted February 18, 2008 Report Share Posted February 18, 2008 FPR=Fuel pressure regulatorCTS=Coolant temperature sensor With no error codes, the LED will remain lit and not blink.. Link to comment Share on other sites More sharing options...
