JRToy4x4 Posted September 13 Report Share Posted September 13 Hi all, I am going to replace the fuel pump on my '87 TSi, but the gas tank is currently about 3/4 full. I am relatively comfortable with mechanical work and have read the topics available but I am still a bit nervous, mostly about the best way to empty the gas tank. Would someone be willing to describe in detail the best way to empty out the tank? For what it's worth, the pump still works. I've read there's a way to jump the pump from the engine compartment but am not sure how exactly this works. Any tips on dropping the tank would also be appreciated. Thanks, Jason Quote Link to comment Share on other sites More sharing options...
TexasQuest Posted September 13 Report Share Posted September 13 There is a drain plug on the bottom of the tank. Quote Link to comment Share on other sites More sharing options...
techboy Posted September 13 Report Share Posted September 13 Yep, Texas is right. There's a drain plug on the left hand side near the fill. 3/4 full is a lot of gas. I'd try to drive it around a bit, get it more empty. Then, jack it up, put a 5 gallon bucket under and remove the plug. Have a 2nd bucket close by in case you got more than 5 gallons still in there. Dropping the tank and replacing the pump is pretty straight forward after you get the gas out. Quote Link to comment Share on other sites More sharing options...
JRToy4x4 Posted September 14 Author Report Share Posted September 14 Thanks! Does the plug usually seal well when you put it back in? Do I need to replace a washer or anything? Quote Link to comment Share on other sites More sharing options...
scott87star Posted September 14 Report Share Posted September 14 It’s got an odd plastic gasket that I’ve never replaced after dumping the fuel out several times. No leaks yet. I would first siphon as much as you can out of the fill port as it can get messy once you drop the plug. Quote Link to comment Share on other sites More sharing options...
admin_JAinsworth Posted September 15 Report Share Posted September 15 Dad on this site offers a replacement on his website. https://dadsengineparts.com/dep/productview.php?product_id=Fuel drain gsk Jimmy 1 Quote Link to comment Share on other sites More sharing options...
psu_Crash Posted September 17 Report Share Posted September 17 Siphon as much as you can out first. Quote Link to comment Share on other sites More sharing options...
JRToy4x4 Posted September 20 Author Report Share Posted September 20 Thanks for the advice! I'll try to get out what I can and drain the rest. I'm glad this forum is still around. Quote Link to comment Share on other sites More sharing options...
