lseguy Posted September 10 Report Share Posted September 10 (edited) posting here since it doesn’t look like I have the ability to post in the main form area. But I wanted to put this together in hope that they could help someone if they do searching. I immediately noticed that my compressor was not turning on regardless of any setting. I started by finding the dual pressure switch for the HVAC system. that is the switch with two prongs that is located just to the right of the accumulator dryer behind the passenger side headlight area as you are standing on front of the car facing the engine. This switch sits below another switch that has wires built-in. After unplugging the dual pressure switch,I used a jumper wire on the wiring harness to bypass that switch as a test. Lo and behold, the compressor turned on with the jumper wire in place. CompareCars GetLanguage Courses after much research, I ordered the following replacement switch: Santech MT0227. in order to replace that switch, the system must first be evacuated of any refrigerant that is within the system. please ensure this is done in the proper manner. some local mechanics will actually evacuate your system for you for free. after the system is evacuated, it’s fairly straightforward to remove the old switch and replace with the new switch. At this point I rented guages and a vacuum machine from advance auto to fully vacuum the hvac system. I also ordered a new dryer. This is the one that I ordered from Amazon: UAC-RD 1149C. i first installed the new drier. Then I did a full vacuum for one hour to remove any moisture that was in the system. (This is a critical step and should be done anytime. Your AC system has been open to the air.). After the vacuum, I closed the blue valve on the guages completely and let everything sit connected for 30 minutes. I then checked the blue gauge to ensure that it was still holding vacuum. It was still holding vacuum, which meant I had no leaks within the system. this particular car had never been upgraded or retrofitted rather to r 134. But rather it still had r 12 when I bought it. keep in mind that our 12 had been removed from the system as part of my troubleshooting and repair work. so while there was no R 12 in it, there was still oil in the system that was compatible with r 12 and not r 134. Finding r 12 is near impossible and when you do, it can be super expensive. And doing a complete and proper change over to r 134 meant swapping out all O-rings in the system, draining the compressor oil and possibly other steps that I was trying to avoid. so after reading more, I opted to go with Redtek refrigerant which is compatible with systems that had r 12. Ordered two cans of refrigerant (6 ozs each) and one can of their oil (3ozs). At this point, I simply followed the basic common instructions on how to add refrigerant and replacement oil into an AC system. Note: for Redtek refrigerant, you use much less refrigerant than you would R134 or R 12. 12.2 ounces is all you need. I ended up using the full 3oz of oil (which also has some amount of refrigerant within that can),and about 8ozs total of Redtek refrigerant. Basically one full can of refrigerant, one full can of oil, and about a half of a another can of refrigerant. my compressor actually kicked on after adding just the 3 ounces of the oil/refrigerant within that can.) At that point, my low pressure was about 39 on the blue gauge which is the recommended psi. And the air coming out of the vent inside the car was cold again. So at that point, I stopped adding any more refrigerant. *EDIT: UPDATE: Read my subsequent post in this thread. 3 ozs of oil is FAR too much. CompareCars and that is how I fixed my AC without having to do a complete R134 changeover. oh: almost forgot: I did change the low and high-pressure ports on the compressor to quick connects. For the low pressure port on the compressor, any of the ac gauge kits sold on Amazon include the proper quick connect fitting for the low side. But the high-pressure connector on my 88 conquest was a smaller diameter than what any of the kits included. UpgradeBathroom Faucets UpgradeBathroom Faucets so, had to order this for the low side from Nostalgic AC parts R-12 to R-134a Adapter High Side 3/16" × 1 Edited October 28 by lseguy Quote Link to comment Share on other sites More sharing options...
psu_Crash Posted September 11 Report Share Posted September 11 R12 uses Ester oil and most 134a systems use PAG oil. The 2 are not compatible. Although you can use ester oil (POE) in a 134a or propane system without issue and it is compatible with the mineral oil that was OEM. The high side is a larger fitting, which you have figured out. 3oz of oil and 12oz of refrigerant doesn't sound like enough, but it's been a LONG time since I did an AC refresh on a SQ. That Redtek stuff is propane based. Not as effiecient as R12 or 134a. I've actually heard of guys using straight propane in their AC wil good results. I'll pass on flammable refrigerant for now. Enough of my rambling 🙂 Glad to hear you got it working! Quote Link to comment Share on other sites More sharing options...
lseguy Posted September 11 Author Report Share Posted September 11 Hi. Per the vendor re: amounts Quick Conversions & Weight Equivalents The Formula: R12 weight specification × 0.35 = RED TEK 12a charge weight Can Equivalents: A single 9 oz can of RED TEK 12a is volumetrically equivalent to 27 oz of R12 (or a 6 oz can is equivalent to roughly 17–18 oz of R12) Quote Link to comment Share on other sites More sharing options...
lseguy Posted September 11 Author Report Share Posted September 11 Regarding the Redtek oil: Key Compatibility & System Details: Refrigerants: It is explicitly compatible with R12, R134a, and R502 systems.[1] Lubricants: It blends seamlessly with both traditional mineral oils(commonly used in legacy R12 systems) and newer synthetic options like PAG and Ester lubricants. [1] Components: It is safe for all standard automotive A/C materials, including compressors, metal components, O-rings, gaskets, and seals. Quote Link to comment Share on other sites More sharing options...
lseguy Posted September 11 Author Report Share Posted September 11 Regarding efficiency “Yes, Red Tek 12a is more thermodynamically efficient than both R12 and R134a. Because it is a hydrocarbon blend (propane/butane), it possesses a higher latent heat capacity and superior thermal conductivity compared to fluorocarbon-based refrigerants.” Quote Link to comment Share on other sites More sharing options...
psu_Crash Posted September 13 Report Share Posted September 13 I'm definitely no pro when it comes to HVAC. Good information! I had never heard of Redtek before. I'm in the process of refurbing the AC on my ol 944. May look into this more. Quote Link to comment Share on other sites More sharing options...
lseguy Posted September 14 Author Report Share Posted September 14 Highly suggest checking it out! 1 Quote Link to comment Share on other sites More sharing options...
CarlosFley Posted October 1 Report Share Posted October 1 Awesome info! Looking forward to trying this out! Quote Link to comment Share on other sites More sharing options...
lseguy Posted October 2 Author Report Share Posted October 2 (edited) Another tip learned after: FSM states that ONLY .5 oz of oil needs to be in the AC system. So I added far too much oil. Fortunately it didnt cause any damage but I'll be evacuating the system again this weekend and replacing the drier (much of the excess oil pools down into the drier) and adding just redtek refrigerant. That should get me close to having the proper amount of oil in the system, while allowing room for a bit more refrigerant itself. So I anticipate even better cooling than I had. Edited October 2 by lseguy Quote Link to comment Share on other sites More sharing options...
