RHD swap with LHD parts
First post in years, but trying to move away from the 10 different FB groups and contribute to this forum instead.
Figured I'd post about my recent challenge.. decided my second Starion would become a parts car after two bearings spun and found the block was cracked. Car has rust and been poorly painted too. Plus it has a manual trans I decided would be better suited swapping into my auto 88 Starion driver.
Anyways, I'm a big JDM fan boy so I decided while the dash was out doing the trans swap, I'd inspect how different all the LHD parts are from RHD. And my dash is already in poor condition so I will do a custom overlay of some sort.
Anyways, I've already relocated the steering column, brake pedal, brake booster, steering box, idler arm, shortened and reflared the oem steering and brake lines. So now I have a steerable and stoppable RHD car and have only purchased a $10 brake line union.
Pending work - gas pedal, clutch pedal, extending harnesses, and dash work of course.
Not sure about my HVAC yet.. that seems about the main thing that the proper RHD parts are necessary. I think I have a solution to retain heat but not sure if I can make AC and ducting fit.
Known differences I plan to live with or fix later on - window switches, turn signal stalk, km/h cluster
Known differences I'll likely never change. Parking brake, fuse box, hood pull, and gas cap release all on driver side still.
Just tried to upload an image and the file limit is so small
Drove it out of the garage under its own power. Still on auto trans and no dash. But always feels better knowing a project can drive instead of being a boat anchor.
How do we add photos to these posts with any decency of resolution??
  • 4 weeks later...
Took it to a car show before the season ends. Drove great. It will take a little bit to get used to driving on the right side.
Now I will continue to extend wires to the right side and work on a dash and transmission swap over the winter.
  • Like 1
Unfortunately, the only way to get better than flip phone resolution photos here is to host them elsewhere. It’s really killing this site and will hopefully be changed at some point. Good luck with the rest of your project!
