Contsi Posted March 8 Report Share Posted March 8 Hello, I hope all are having a good winter. Much snow in the northeast. 1987 Conquest TSi Long before I learned of the warping issue with these manifolds, I had the car in a shop for an exhaust leak. The gasket was replaced but I don't believe the leak went away as it is leaking (near the firewall). I also believe there is a small crack (I'll have to confirm). Could someone advise on finding a good replacement? I guess it would have to be corrected by planing it down. I also read about stress relieving, but that if already planed dow then that would no longer be needed. Thanks for any help Link to comment Share on other sites More sharing options...
TexasQuest Posted March 8 Report Share Posted March 8 G54B Exhaust Manifold - MKS Motorsport Mikie is a great guy with tons of parts for our cars. Make sure the rear most exhaust stud is not broken or stripped out causing a leak. That was a VERY common issue with these cars since they didn't have a flex section in the exhaust system. 1 Link to comment Share on other sites More sharing options...
admin_JAinsworth Posted March 9 Report Share Posted March 9 Mikie Sorrell at MKS carries a stressed relieved exhaust manifold and the gasket needed. https://mksmotorsport.com/product-category/exhaust/ Randy Gaines aka DAD carries the gasket, studs, and locking nuts needed. https://dadsengineparts.com/dep/browse.php?searchStr=manifold&submit=Search Jimmy Link to comment Share on other sites More sharing options...
Contsi Posted March 9 Author Report Share Posted March 9 Thanks for the replies guys. I will look into these, once I'm able to confirm the true condition of mine. I'm guessing these are remanufactured; is the fitment stock like? Also, the shop did tell me that they had to helicoil the the rear most exhaust stud, not sure if it was pulled, or stripped. I suspect the manifold was worped then and they just didn't know and didn't addressed. Again, this was a long time ago. Link to comment Share on other sites More sharing options...
Contsi Posted March 10 Author Report Share Posted March 10 Looked at the manifold today and sure enough, that last bolt had worked itself out, and the nut on the top wasn't very tight. So I tighten both and will keep an eye on it. Thanks again Link to comment Share on other sites More sharing options...
Alpina_Blue Posted March 15 Report Share Posted March 15 If anyone does need a new exhaust manifold, the new MKS part mentioned above is very high quality. I got that along with the steel exhaust manifold gasket and ARP hardware he sells last summer, very pleased with all of it. At nearly 40 years old, we’ll all need to replace it at some point, awesome that MKS has it available Link to comment Share on other sites More sharing options...
