Rev383 Posted August 4, 2025 Report Share Posted August 4, 2025 Found my issue with bucking it was the in tank filter. Im taking the tank down and fully cleaning it, is there a parts store filter i can use to replace this one or can i use a 100 micron before the pump and be fine Quote Link to comment Share on other sites More sharing options...
admin_JAinsworth Posted August 4, 2025 Report Share Posted August 4, 2025 Dad aka Randy Gaines, a long time trusted member and part supplier for our cars offers this on his website: https://dadsengineparts.com/dep/productview.php?product_id=Inline Fuel filt Jimmy 2 Quote Link to comment Share on other sites More sharing options...
kev Posted August 4, 2025 Report Share Posted August 4, 2025 When you say 'cone filter', there is a cone style filter at the outlet of the pump that is prone to cause issues...most remove it. The 'in-tank' filter is the cylindrical filter on the end of the pick-up tube. The cylindrical filter is still available through the site linked above. Or go with an inline filter. either will work fine. Although, I wouldn't run both together on a suction line. You want the pump to 'pull in' gas with ease. Put your fine filter in the high-pressure line, the suction line should be as open as possible. The stock cylindrical filter is all I use on the suction line and now Dad sells one with a coarser filter than even stock...which is what I'd use in the future. Quote Link to comment Share on other sites More sharing options...
Rev383 Posted August 5, 2025 Author Report Share Posted August 5, 2025 (edited) Yes to the end of the pickup that is what i was meaning. I have the stock filter at the block changed so would it be okay just to run that? I have not found the other filter you are talking about. I am going to tank the tank down and muriatic acid it to clean it real well. Edited August 5, 2025 by Rev383 Quote Link to comment Share on other sites More sharing options...
admin_JAinsworth Posted August 5, 2025 Report Share Posted August 5, 2025 https://dadsengineparts.com/dep/productview.php?product_id=tank filter Jimmy Quote Link to comment Share on other sites More sharing options...
Dad Posted August 5, 2025 Report Share Posted August 5, 2025 I run both the in tank filter ( factory) along with the inline filter with no issues. Dad Quote Link to comment Share on other sites More sharing options...
