JRToy4x4 Posted March 9, 2025 Report Share Posted March 9, 2025 Hello, I am trying to bring a modified Conquest back to a milder level. It presently has an 18g turbo along with a rising rate fuel pressure regulator (at least that's what I thought it was when it was installed 20 years ago). I plan to replace this with a 14g turbo, and am wondering if the additional fuel pressure regulator would even be needed? I'd like to simplify the car a bit. I do have an A/F ratio gauge (based off a 1-wire O2 sensor) to keep an eye on things. Thanks, Jason Quote Link to comment Share on other sites More sharing options...
tux Posted March 10, 2025 Report Share Posted March 10, 2025 More fuel for more boost. with a 14g at stock boost levels you should be fine with the stock fpr. i would confirm against a wideband o2 when making changes Quote Link to comment Share on other sites More sharing options...
admin_JAinsworth Posted March 11, 2025 Report Share Posted March 11, 2025 Generally fuel pressure should be ~38 psi when not in boost. Pressure should rise one psi per pound of boost. ( e.g. 5 pounds of boost should have 38 psi plus 5 or 43 psi of fuel pressure). Jimmy Quote Link to comment Share on other sites More sharing options...
GoldStar Posted March 11, 2025 Report Share Posted March 11, 2025 Ditto the above, but another reason for adjusting the fuel pressure is if you have non-stock injectors. I know my mystery/Delphi injectors ran better when at 42-43 PSI idle. Definitely recommend a wideband sensor for the AFR reading. If you have any issues/doubts over your current fuel pressure regulator, spaturbousa make a bolt-in adjustable FPR that works quite well for our cars. Quote Link to comment Share on other sites More sharing options...
JRToy4x4 Posted April 29, 2025 Author Report Share Posted April 29, 2025 Good info, thank you! I am sorry I didn't reply sooner, I thought I was getting emails when replies posted. Is there a way to install a wide band 02 sensor on the '87 cars? Quote Link to comment Share on other sites More sharing options...
scott87star Posted April 29, 2025 Report Share Posted April 29, 2025 My 87 has run a wideband O2 mounted in the factory spot for 30K plus miles without issue, still working fine. If you’re still running the factory ECU you can run the narrow band output from the wideband ( most have them) to the ECU. Quote Link to comment Share on other sites More sharing options...
