cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July 2nd 2022: Drivers seat re-webbing Fuel sending unit inspection Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July 3rd 2022: Drivers seat installation Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July4th 2022: Underhood inspection Turbo check Spark plug check Valve cover removal/ head inspection Brake teardown Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July5th 2022: Wheels back from refurbisher Rear brake tear down Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July 7th 2022: Thermostat/coolant checks Coolant drain Brake backing plate por 15 Damage hard pipe removal Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July 8th 2022: leaking brake hard line removal Leaking turbo coolant line Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July 9th 2022: Tires installed on refurb wheels Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July 10th 2022: Brake master removal Clutch master removal Brake booster removal New brake master New clutch master New reseviors (clutch and brake) Throttle body removal Delphi fuel pump ordered (will not be the final) Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July 11th 2022: Identified possible new fuel sender Rear caliper tear down Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July 12th 2022: Fuel sender research Brake parts inspection Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July 13th 2022: Brake booster install Brake master install Clutch master install Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 July 14th 2022: Brake hard line bending Brake hose replacement Sending unit checks on replacement fuel tank Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 (edited) July 16th 2022: Throttle body inspection brake install Fuel sender tests Brake bleed Clutch slave removal Edited November 3, 2022 by cyclonegrey Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 3, 2022 Author Report Share Posted November 3, 2022 (edited) July 17th 2022: Wheels on!! gas tank sealing Edited November 4, 2022 by cyclonegrey Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 4, 2022 Author Report Share Posted November 4, 2022 July 19th 2022: Throttle body Issues with Delphi pump connection Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 4, 2022 Author Report Share Posted November 4, 2022 July 20th 2022: Installed throttle body replaced turbo water line Tested injectors for operation but not flow Added coolant pulled plug and checkd for spark Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 4, 2022 Author Report Share Posted November 4, 2022 July 21st 2022: Reinstall intake piping coat of leather conditioner Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 4, 2022 Author Report Share Posted November 4, 2022 July 22nd 2022: Montero fuel sender testing, modification adjustment and pigtail Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 4, 2022 Author Report Share Posted November 4, 2022 (edited) July 23rd 2022: Wipers and wiper adapters Walbro fuel pump install fuel tank sender install Cone filter replace with wix canister filter Install gas tank add gas First start in 27 years! First drive! Edited November 4, 2022 by cyclonegrey Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 4, 2022 Author Report Share Posted November 4, 2022 July 29th 2022: Vacuum advance replacement Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 4, 2022 Author Report Share Posted November 4, 2022 July 30th 2022: Injector connectors replaced and rpm restricted to 4k Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 4, 2022 Author Report Share Posted November 4, 2022 July31st 2022: Distributor mechanical advance Quote Link to comment Share on other sites More sharing options...
cyclonegrey Posted November 4, 2022 Author Report Share Posted November 4, 2022 August 1st 2022: Wiper motor gearbox cleaning Wiper arm pivot lock up and removal Quote Link to comment Share on other sites More sharing options...
