Help identifying what brand
I appreciate it. Trying to learn the car searching the forum. I appreciate your help. Do you happen to know if these are rebuildable if these end up being shot? I wont be able to tear down the car until a few days from now. Just trying to do some research on stuff in the mean time.
So, i can only confirm camber plates are mookeh.
Below the plates you could have coilovers or regular MacPherson struts.
If coilovers they are rebuild able.  If struts depends on the cartridge.
Mookeeh, or MK1 mostly sells on eBay.  You can look up that seller name and should get a hit.  He also goes by Starionpartsfactory on there.  I've quite a few parts on my car from them these days actually. Not too many other places to get stuff.
only wear item on the caster plate would be the mono ball. If it has C-clips its rebuildable If not it would probably need to be cut off and a replacement welded on the plate. If its a quality piece it should last a long time. It will raddle when its shot.
  • 2 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
