VIFlatty Posted September 13, 2015 Report Share Posted September 13, 2015 hello to everyone. I have an 85 and it wont start everything is stock . I have read threads over the past few weeks. i try downloading the fsm but it never loads and i have been using info throughout the forum to help troubleshoot. tach moves when i crank but there is no voltage at the coil. the knockbox shows 12volts at the connector. checked fusible links and cleaned them I am also getting 12v there.tested for continuity between battery neg and coil. I really appreciate the amount of info on this forum .i am looking for troubleshooting help whether it be a snapshot of the no start troubleshooting section in the fsm or a list of things to look for since i am getting 0v at the coil. thanks in advance! Quote Link to comment Share on other sites More sharing options...
freebird Posted September 14, 2015 Report Share Posted September 14, 2015 if you have 0 v at the coil when the ign. key is on.then you have the coil wires on wrong. or a broken/open wire there should be batery. volts there Quote Link to comment Share on other sites More sharing options...
VIFlatty Posted September 14, 2015 Author Report Share Posted September 14, 2015 Awesome thanks yeah it started before so probably broken wire finally got the tps reset and now this...I will trace the wires and see if i can find something.Thanks freebird! Quote Link to comment Share on other sites More sharing options...
techboy Posted September 15, 2015 Report Share Posted September 15, 2015 May even be possible your coil is bad ... but it won't fire with 0 volts. Quote Link to comment Share on other sites More sharing options...
VIFlatty Posted September 15, 2015 Author Report Share Posted September 15, 2015 thanks techboy i have a spare coil becuase originally i thought that was the problem but then i realized no voltage at coil.im guessing if there is a short in the wire i should just run a new one? can i test this by running a wire from the + side of the battery to the + side of the coil? i appreciate the help. Quote Link to comment Share on other sites More sharing options...
VIFlatty Posted September 22, 2015 Author Report Share Posted September 22, 2015 Got a day off so im working on the car. i got 12 v at coil when i ground my multimeter to body. grounding on the neg - terminal of the coil reads 0v. Shouldnt i also get 12v across the terminals of the coil? Quote Link to comment Share on other sites More sharing options...
StarquestRescue Posted September 22, 2015 Report Share Posted September 22, 2015 (edited) Got a day off so im working on the car. i got 12 v at coil when i ground my multimeter to body. grounding on the neg - terminal of the coil reads 0v. Shouldnt i also get 12v across the terminals of the coil?No, the ignition box grounds the coil to create a spark at the correct intervals. Edited September 22, 2015 by StarquestRescue Quote Link to comment Share on other sites More sharing options...
StarquestRescue Posted September 22, 2015 Report Share Posted September 22, 2015 (edited) The tack needle jumping when you crank the engine is an indication you are getting spark. Look for problems on the fuel side of things. http://www.ebay.com/...a42041b&vxp=mtr http://www.ebay.com/...1ab1e80&vxp=mtr Does this car have a intercooler and 5 lug wheels? Edited September 22, 2015 by StarquestRescue Quote Link to comment Share on other sites More sharing options...
VIFlatty Posted October 4, 2015 Author Report Share Posted October 4, 2015 hey guys thanks for the help! got the car to run by spraying starting fluid . it ran for over ten minutes then died.after it died i lost spark.no tach while cranking. tried starter fluid again and it started right up. again ran for awhile then died no spark. I checked the pick up coil terminals and they are out of spec 1188 ohms. I think this means its the pickup coil? problem is i cant find a place to order one from. starquestrescue this is a non intercooled flatty manufactured 10/84 Quote Link to comment Share on other sites More sharing options...
StarquestRescue Posted October 4, 2015 Report Share Posted October 4, 2015 (edited) Try a different knock box/igniter the plastic ones were know for intermittent no start. May be mutiable problems. Edited October 4, 2015 by StarquestRescue Quote Link to comment Share on other sites More sharing options...
VIFlatty Posted October 5, 2015 Author Report Share Posted October 5, 2015 Unfortunately I don't have an extra knock box . If the knockbox is bad wouldnt my injectors still fire while cranking? Right now when I lose spark I lose fuel too. I have been reading that a bad knockbox is fixable but how do I open it? Quote Link to comment Share on other sites More sharing options...
freebird Posted October 5, 2015 Report Share Posted October 5, 2015 I have 2 of these black boxes on fenderwell next to the coil...(knock box)It does sound like it is... the cause of loss spark.Lots of guys have had the same symptoms.lmk if you need one, pay my one way to Florida and ill install it and help you with whatever else you need....jk..you would have to pay for my wife to come too....lol My G-grandma lived in kissimmee....I love that area of FL....pretty close to Clearwater right? Quote Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted October 14, 2015 Report Share Posted October 14, 2015 The fuel pump is turned off if the motor isn't turning as a safety feature. The only way the computer knows the car is running is from the knock box. Quote Link to comment Share on other sites More sharing options...
VIFlatty Posted October 25, 2015 Author Report Share Posted October 25, 2015 Thanks Mike and Freebird! Im pretty sure it is indeed the knockbox. Freebird I pm'd you about that offer lol. I really need that knockbox!! I am a few hours away from clearwater but its not a bad drive. The car is in Melbourne on the east coast . Quote Link to comment Share on other sites More sharing options...
