mstieg Posted September 10, 2015 Report Share Posted September 10, 2015 Are these available? I have ST front & back with the standard poly mounts. Was talking with my mech and adjusting the pre-load may help retain certain settings with the D2s while being tight and streetable. Link to comment Share on other sites More sharing options...
MPGorBOOST Posted September 10, 2015 Report Share Posted September 10, 2015 Not sure if you're referring to adjustable end links but maybe check with GNT performance. I picked up a pair of universal end links from Energy Suspension before GNT was around and modified them. I replaced the bolt with all-thread and cut the spacer as needed. Link to comment Share on other sites More sharing options...
TexasQuest Posted September 11, 2015 Report Share Posted September 11, 2015 Basically all you need to make adjustable endlinks is a fully threaded bolt and nuts to position the endlink bushings. Link to comment Share on other sites More sharing options...
ucw458 Posted September 12, 2015 Report Share Posted September 12, 2015 Moving the sway bar end links up or down wont do much. It also wont "pre-load" the sway bar unless you only move one side. But you only want to do that if you're circle track racing. Link to comment Share on other sites More sharing options...
