Diesel folks here?
vbrad511
My buddy's got a bobcat with a Yanmar (?) diesel 4 cylinder in it. He was using it a while back, pushing pretty hard and noticed it was running HOT. He shut it down, and as he did it blew the cap off the coolant tank and cracked it. Said he heard something like a pop or crack. He let it cool down, filled the AF and fired it back up, but says it's running badly, like it's missing on a cylinder or two. He pulled the head and says the gasket doesn't look like it's blown, and the head doesn't look damaged. Suggestions on where to look next?
I would check the fuel filter to be honest.... was on a bob cat last week and after it warmed it it ran like poooo. and the fuel filter was the issue.. also.... before they pulled the head di they happen to take compression numbers? diesels like good compression up in the 300 range. also,,, that has a mechanical pump.... check the actual pump.... as in timing.... i think that is chain drive but not positive. if its out of time,,,, it will run like pooo too... diesel has no spark just when the fuel is sprayed as a timing point. one more thing.... is there cross contamination of oil and antifreeze at all? does it smoke while running? if so what color? is it white,,, but not sweet smelling? Edited by wrngwae
one big thing to check on a diesel is the exh ,, the dead cyl will be runing cold so the exh runner for the miss firing cyyl will not get as hot as a good cyl , also cracking an inj line will cause that cyl to not fire no change means that cyl is not fireing
problem most of these tests have to be done while to gather
Thats where im at,,,, its already tore down... a lot of people tend to tear down motors to diagnose.. it should be diagnosed before tear down unless it is not running or you have a rod hanging out of the block lol...
if one tears it down to inspect before diagnostic test, rebuild he must to avoid future heartache
CUMMINS FTMFW yO
that only works if the problem is mechanical and not fuel system related ,, many times it can be worth the cost of a head gasket, just to get it back to gather and do a complete diagnosis then if necessary tear it back down
yep hind sight ain't worth much ;) most times people aren't aware of just what all can be found out
while the engine is to gather , that can not be found once it's apart , I can't count the number of times I have been in that position by customers who ripped some thing apart with out doing a single test ,, leaving me in the dark as to what their problem really is
