Shelby Posted August 7, 2014 Report Share Posted August 7, 2014 I got sort of a problem, my g-son accidently lost the Freon out of my 4 ton package unit , and buying a 30 lb cylinder is out of the question right now , I only need like 10 lbs of R22 if any one can help me out please pm me , thank you Link to comment Share on other sites More sharing options...
ucw458 Posted August 7, 2014 Report Share Posted August 7, 2014 R22 has shot up in price in the last few years. It's around $350 a bottle now. I remember when it was $50 a bottle. You would be better off buying a bottle and doing it yourself. Most companies charge around $60-70 per pound to recharge your system. Wish I could help but I don't have any R22 right now and I'm kinda far away. Link to comment Share on other sites More sharing options...
Shelby Posted August 8, 2014 Author Report Share Posted August 8, 2014 I still have my MAC license but I have no use for a 30 lb bottlesaw some listed on ebay for like $158 bottle I realy would love to refill it with r12 but that's not possiblenothing they have ever given us works any where close to as well as r12 Link to comment Share on other sites More sharing options...
starion1991 Posted August 8, 2014 Report Share Posted August 8, 2014 (edited) Shelby, your best bet is to find someone locally that will charge your unit up. A jug of r22 here in Phoenix is about 400 bucks wholesale. That stuff ain't cheap. Also R409 is a direct drop-in for R12, just can't rember which one, R409a or R409b, in case you ever want to charge a car with r12 up Edited August 8, 2014 by starion1991 Link to comment Share on other sites More sharing options...
Shelby Posted August 8, 2014 Author Report Share Posted August 8, 2014 Shelby, your best bet is to find someone locally that will charge your unit up. A jug of r22 here in Phoenix is about 400 bucks wholesale. That stuff ain't cheap. Also R409 is a direct drop-in for R12, just can't rember which one, R409a or R409b, in case you ever want to charge a car with r12 up doesn't r409 use the newer oil,, if so deff not a direct drop in , and from the last pressure chart I saw , isn't r409 a very high pressure Freon like the newer one's used in home a/c units, just asking first time I heard about r409 being useable for r12 , but will deff look into it, my 92 caravan is still r12 , nothing is better at removeing heat then r12 and at a much lower pressure then any of the other freons Link to comment Share on other sites More sharing options...
ucw458 Posted August 9, 2014 Report Share Posted August 9, 2014 I disagree. A R12 system properly charged with 134a works just as well as it does with R12. IF it doesn't work as well then you are not charging it right. For the conversion drop in an 8 oz oil charge then the proper amount of 134a. That's it. You don't have to flush the old oil out. I've done it many times and it has never failed to work properly. Don't charge by pressure on cars, charge by weight. And always take temp readings between the intake and output air. You should get at least a 20 degree drop in temp on the output. If not you haven't charged it right. My 91 toyota and my SQ are both R12 systems. Both have 134a in them and both will freeze your butt off on a 100 degree day. Link to comment Share on other sites More sharing options...
Shelby Posted August 9, 2014 Author Report Share Posted August 9, 2014 I disagree. A R12 system properly charged with 134a works just as well as it does with R12. IF it doesn't work as well then you are not charging it right. For the conversion drop in an 8 oz oil charge then the proper amount of 134a. That's it. You don't have to flush the old oil out. I've done it many times and it has never failed to work properly. Don't charge by pressure on cars, charge by weight. And always take temp readings between the intake and output air. You should get at least a 20 degree drop in temp on the output. If not you haven't charged it right. My 91 toyota and my SQ are both R12 systems. Both have 134a in them and both will freeze your butt off on a 100 degree day. I did not say they do not all work , whats the high side pressures on all the diff freons not just 12 and 134 1 Link to comment Share on other sites More sharing options...
Edde Posted August 10, 2014 Report Share Posted August 10, 2014 I thought the topic was home a/c Link to comment Share on other sites More sharing options...
ucw458 Posted August 10, 2014 Report Share Posted August 10, 2014 I did not say they do not all work , whats the high side pressures on all the diff freons not just 12 and 134 Well that's a question that cannot be answered without further info. Inside/outside temp, rpm of the compressor, condition of the equipment, amount of charge, which type of refrigerant, amount of airflow,.... all affect pressure. You started this topic talking about R22 and a package unit then segwayed into R12 as if the two were the same. I'm not sure what topic you are on right now. FYI "Freon" is a Dupont brand name for their line of R22. No other manufacturer can use that name and no other refrigerant is called "Freon". Link to comment Share on other sites More sharing options...
Shelby Posted August 10, 2014 Author Report Share Posted August 10, 2014 hum in 1965 the yr I took my first chylr a/c course ,, what did they call R12 IF NOT A FREON GAS sorry bout the caps . just asking not arguing maybe it's like a starter bendix even bendix was a manufacture s name it was almost universally used to id a starter drive gear Link to comment Share on other sites More sharing options...
ucw458 Posted August 10, 2014 Report Share Posted August 10, 2014 They probably called it by the proper name, "refrigerant". That's what the R stands for in the classification. In the AC trade we don't call everything freon. In fact we find it funny when homeowners say they think they just need freon. Link to comment Share on other sites More sharing options...
