starion1991 Posted July 30, 2014 Report Share Posted July 30, 2014 I've got a quick question about 4g63s I've got a buddy of mine selling me 2 complete motor sets out of eclipses. First one is a automatic 6 bolt out of a 1990 talon, second one is a 5spd 7 bolt out of a 95 second gen eclipse. My question is would the same bell housing adaptor for a r154 bolt up to both motors, or would I need one the 6 bolt and one for the 7 Only reason I'm asking is id like to drop in the 7 bolt for now, while I build the 6 bolt up. Link to comment Share on other sites More sharing options...
ucw458 Posted July 30, 2014 Report Share Posted July 30, 2014 They are interchangeable. They are called 6 bolt and 7 bolt because of the # of bolts holding the trans to the block. A 6 bolt block will fit on a 7 bolt trans but one trans bolt hole wont line up with anything. Same with a 7 bolt block on a 6 bolt trans. 7 bolt head is better than a 6 bolt head but there are minor things that need to be done like widening the head bolt holes to make it fit properly. 6 bolt uses 1mm thicker head bolts. Oil flows around one of the bolts to the head. If 6 bolt head bolts are used on a 7 bolt head without enlarging the holes you can starve the head of oil. 6 bolt block is stronger and has better bearings. Link to comment Share on other sites More sharing options...
jinx Posted July 30, 2014 Report Share Posted July 30, 2014 its actually 6 or 7 bolts holding the flywheel to the crankI wouldn't waste time "building" either block if its 'healthy'. DSM motors seal up and wear very wellFolks get beastly power from them http://www.dsmtuners.com/forum/dyno-talk.123/I assume you're headed there if u goin with a big heavy 154Either head make great power and torque Link to comment Share on other sites More sharing options...
techboy Posted July 30, 2014 Report Share Posted July 30, 2014 So, to follow up w/ the other guys you can theoritically do what you want to do. And BTW jinx is correct a/b the 6 vs. 7 bolts. The only thing that is going to be tricky IMO has nothing to do with the 6 and 7 bolts .... both motors are slightly different from a electronics point of view. So, you'll be altering your Quest harness to work w/ a 7 bolt and then you'll have to alter it again for the 6 bolt. Specifically concerning the CPS and the CAS. I agree w/ you though, building a 6-bolt is the way to go, practically bullet proof. I have a bare 6-bolt on a stand right now myself. Link to comment Share on other sites More sharing options...
ucw458 Posted July 30, 2014 Report Share Posted July 30, 2014 its actually 6 or 7 bolts holding the flywheel to the crank Is it? I was told it was the bellhousing bolts years ago. I don't own a DSM so I never questioned it. Link to comment Share on other sites More sharing options...
LSQuest88 Posted July 31, 2014 Report Share Posted July 31, 2014 (edited) Yes that is correct its the number of flywheel bolts. If I remember right though at one time I mated a 1g trans to a 2g 7 bolt block and I thought that it had an extra bolt hole in that block that the trans didn't or vice versa so you might be on to something there. This was back like 10 years ago though so don't quote me on that. Edited July 31, 2014 by LSQuest88 Link to comment Share on other sites More sharing options...
Guest Posted July 31, 2014 Report Share Posted July 31, 2014 I prefer the 1g engines, bigger everything. Bigger rods, larger intake/ exhaust ports on head and no lame crank walk. Those 4G63 engines are really sturdy. People blow them up for the same reason people blow up 4g54's, they boost them to the moon without proper tuning. Link to comment Share on other sites More sharing options...
Shelby Posted July 31, 2014 Report Share Posted July 31, 2014 both engines you'll need to tighten the t-belt tentioner to it's tightest position so the auto tensioner has no slack , if you go by factory instructions you can have the t-belt jumpand that is real bad also high pressure clutch pp 's will need thrust bearing checking from time to time , like every 30k or so , samefor checking belt tention adjustment Link to comment Share on other sites More sharing options...
starion1991 Posted July 31, 2014 Author Report Share Posted July 31, 2014 Well, ended up scoring both motorsets for a killer price. 7 bolt has been rebuilt according to the customer that left it at my buddy's shop. But I'm not betting on it. It dose look like it's had some work done to it to say the least. It has a new timing belt and all the timing marks are lined up. Dose not look like they've ran it yet. I'll be cracking the oil pan off of it tomorrow to take a quick peek. My plan is going to be to use the 7 bolt for fabbing the swap in and build the 6 bolt in the meantime. The 6 bolt came out of a automatic car with low miles. May crack that one open and see what I've got to work with. Worst case, both motors may be bad but I got basically 2 complete motor sets minus ecu and harness for scrap price, the customer couldn't pay his shop bill/didn't have a place to store the cars and gave the motors and cars to my buddy as payment. Link to comment Share on other sites More sharing options...
87redcat Posted July 31, 2014 Report Share Posted July 31, 2014 Nice score. Good luck with the build! Link to comment Share on other sites More sharing options...
jinx Posted July 31, 2014 Report Share Posted July 31, 2014 only thing that is going to be tricky IMO has nothing to do with the 6 and 7 bolts .... both motors are slightly different from a electronics point of view. So, you'll be altering your Quest harness to work w/ a 7 bolt and then you'll have to alter it again for the 6 bolt. Specifically concerning the CPS and the CASOn projectzerog DJ discussed he preferred the front cam and crank sensor of the 2nd gen, to get away from the rear mounted CAS.Can't remember what ecu, or if he just repinned.... info is out there tho both engines you'll need to tighten the t-belt tentioner to it's tightest position so the auto tensioner has no slack , if you go by factory instructions you can have the t-belt jumpand that is real badI'd call that one flaw with the DSM. Some times the belt is so slack u wonder how it runs like that. Next minute its snug.I put my cover back on because I didn't like seeing it. Made me nervous - lol. Other DSMs, same thing I've noticed tooI recall "haztoys" posting he modified all his tensioners by gutting them and threading for a bolt and lock nut Link to comment Share on other sites More sharing options...
LSQuest88 Posted July 31, 2014 Report Share Posted July 31, 2014 ^^^been there. Had a timing belt jump on me on a cold morning back in the day. Seems like they tighten up once motor is warmed up then get loose after everything cools off. I finally ended up going with an expensive greddy kevlar timing belt. No more problems after that...With timing issues anyway Link to comment Share on other sites More sharing options...
Shelby Posted July 31, 2014 Report Share Posted July 31, 2014 all you have to do is depress the auto tensioner until it has no more room to collapse , all the auto tensioner is , is a very heavy duty shock it will depress under constant pressure , so no room to depress , no getting slack in belt Link to comment Share on other sites More sharing options...
techboy Posted August 1, 2014 Report Share Posted August 1, 2014 I just changed my belt a year ago to a Gates Racing belt b/c I was getting the tight/slack thing going on, on a belt that had only been on the car about 2 years. It made me nervous so I replaced it before something happened. I also (as Shelby mentioned) installed my tensioner differently than I had in the past so that it didn't have as much room. But even that can sometimes be tricky to do, esp if the motor is still in the car. Should be easier in a Quest though b/c the timing components are facing forward - not sideways. And, in starion1991's case he'll be doing it on a stand anyway. Good luck with the build. This is something I may venture into myself w/ my Quest years down the road since I'm a DSM guy first. Link to comment Share on other sites More sharing options...
ucw458 Posted August 1, 2014 Report Share Posted August 1, 2014 You guys talking about timing belts being loose makes me wonder. Are you tensioning the happy face pulley correctly before pulling the grenade pin on the hydrolic tensioner? The hydrolic tensioner must be fully compressed and the pin in it before setting the static happy face pulley. Link to comment Share on other sites More sharing options...
Shelby Posted August 1, 2014 Report Share Posted August 1, 2014 You guys talking about timing belts being loose makes me wonder. Are you tensioning the happy face pulley correctly before pulling the grenade pin on the hydrolic tensioner? The hydrolic tensioner must be fully compressed and the pin in it before setting the static happy face pulley. that's what we are talking about , once you pull the holding pin , you continue to compress the tensioner further to remove the extra travel distance of the plunger other cars using mits's motors do not use that auto adjuster tensioner factory fsm tells you to lossen both rocker arm assy's so there is no turning force on the cams when replacing the cam belt but if you use two long boxed end wrenches and tie them to gather with cam gear marks in alignment you can replace belt with out removing valve cover you also need two belt holding clamps or small vise grips ,, also do not place crank mark @ tdc be a little before tdc then turn crank to tdc after belt is in the notches to get the belt tight and under load , with crank pully mark at tdc you can not install belt with proper tension Link to comment Share on other sites More sharing options...
ucw458 Posted August 1, 2014 Report Share Posted August 1, 2014 Link to comment Share on other sites More sharing options...
Shelby Posted August 1, 2014 Report Share Posted August 1, 2014 very informative post , thank you kind sir Link to comment Share on other sites More sharing options...
importwarrior Posted August 1, 2014 Report Share Posted August 1, 2014 Jafromobile has some great 4G63 engine videos Link to comment Share on other sites More sharing options...
