Ro_the1st Posted July 22, 2014 Report Share Posted July 22, 2014 Terribly sorry if this question was already answered however I just need to be 100% I have a 88 Starion with rust that I want to swap the drive train into my 87 quest. What parts are NOT compatible if any. Quest has seized motor but head, TB are mint. I know im swapping my 88 ecu into my 87. Any input is greatly appreciated Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted July 22, 2014 Report Share Posted July 22, 2014 There are several minor wiring harness, sensor, and pigtail differences between the 88 and 87 years but overall the engine is exactly the same. 1 Link to comment Share on other sites More sharing options...
Ro_the1st Posted July 23, 2014 Author Report Share Posted July 23, 2014 Thank you very much,I will start looking into what harnesses and sensors I will need. Link to comment Share on other sites More sharing options...
importwarrior Posted July 23, 2014 Report Share Posted July 23, 2014 I know the knock box or ignition box is different for sure.if you do just the engine and head it should be a bolt in and go.if sensors are different just put 87 sensors in the 88 engine intakeand that would be it. Link to comment Share on other sites More sharing options...
Ro_the1st Posted July 23, 2014 Author Report Share Posted July 23, 2014 Thank you, getting closer to the reveal of my first quest. Link to comment Share on other sites More sharing options...
ucw458 Posted July 23, 2014 Report Share Posted July 23, 2014 (edited) There are some minor differences between the 88-89 and the older cars. The water pump and coolant crossover are different and are not interchangable. 88-89 cars have the turbo coolant line going to the water pump. 84-87 cars have it in the crossover pipe. Not a huge deal just don't mix them up or you will end up with either no turbo coolant location or two turbo coolant locations. The T-stat outlet is also a different shape but no big deal. Just use the radiator hose meant for the year t-stat outlet you are using. All the sensors are the same on 87-89 cars. But the temp sender for the gauge is a 2 prong on 88-89 instead of the 83-87 1 prong. You can use the 1 prong on the 88-89 cars but that disables 1 function in the auto heater. The second prong is a thermal switch. In 86-87 cars the thermal switch is near the heater core. All that switch does is tells the HVAC computer when the coolant has warmed up. It's there so on cold mornings when the heat is set to auto and below 90 deg the blower wont activate until the coolant warms up. It's a comfort feature so you aren't getting blasted with cold air while the engine warms up. Edited July 23, 2014 by ucw458 Link to comment Share on other sites More sharing options...
Ro_the1st Posted July 23, 2014 Author Report Share Posted July 23, 2014 This is why I love this community thanks again members. Link to comment Share on other sites More sharing options...
TexasQuest Posted July 24, 2014 Report Share Posted July 24, 2014 There are some minor differences between the 88-89 and the older cars. The water pump and coolant crossover are different and are not interchangable. 88-89 cars have the turbo coolant line going to the water pump. 84-87 cars have it in the crossover pipe. Not a huge deal just don't mix them up or you will end up with either no turbo coolant location or two turbo coolant locations. The T-stat outlet is also a different shape but no big deal. Just use the radiator hose meant for the year t-stat outlet you are using. All the sensors are the same on 87-89 cars. But the temp sender for the gauge is a 2 prong on 88-89 instead of the 83-87 1 prong. You can use the 1 prong on the 88-89 cars but that disables 1 function in the auto heater. The second prong is a thermal switch. In 86-87 cars the thermal switch is near the heater core. All that switch does is tells the HVAC computer when the coolant has warmed up. It's there so on cold mornings when the heat is set to auto and below 90 deg the blower wont activate until the coolant warms up. It's a comfort feature so you aren't getting blasted with cold air while the engine warms up.Great info! Didn't know this. Link to comment Share on other sites More sharing options...
