Burton Posted April 24, 2013 Report Share Posted April 24, 2013 (edited) EDIT- 5/10/13...... Here's the pricing. I will offer these two ways..... With LED bulbs and a new LED flasher, and without Sequential setup #1- $120: This will come with LH and RH OEM bulb housings that have had the sequential modules wired in. The outer bulb 2 wire sockets are also replaced by new 3 wire ones. As with all my products, it will also come with detailed installation instructions. and any necessary hardware. You will have to provide your own LED bulbs and LED flash relay Sequential setup #2- $170: This will come with everything in Setup #1, but also comes with 6, 12 LED bulbs (the ones in the video above are 9 LED), as well as a turn signal flash relay designed to work with LED bulbs. I purchase this stuff thru superbrightleds.com, and while the quality of their products is top-notch, they are also more expensive than the cheap LED bulbs on the market. I've had horrible luck with cheap LED's so I will not use them in conjunction with any of my products. If my name is going to be on something, I want it to be of the highest quality possible. PLEASE NOTE!!!!!!!!!!! The sequential module is designed to run LED bulbs, The OEM style turn signal flash relay is not. If you do not replace the flash relay with one made to run LED's, the lights will not work. If you use standard bulbs instead of LEDs, your lights will not work. I currently have 2 LH and 2 RH bulb housings on site, and another one of each on the way, so for right now, I am only offering 3 sets. These will be built in order of purchase, and should take about 2 weeks from full payment to have ready to go. First come, first served;) Prices include shipping and Paypal fees. Paypal: markewade@gmail.com Prices also include a core charge for your old, un-modded bulb housings.... After installing your sequential bulb housings, you can send me your old housings and get $20 back. Thanks! I got some sequential modules to setup some sequential turns on my tail lights. I still got a little more wiring to figure out, and have to buy some LEDs yet, but if they turn out good, I'd be down to make some more if there's interest. The modules require the use of LED bulbs so there will be the bulb expense, but aside from that, I think I'd be able to offer a plug and play setup for around $125-150 plus bulbs. Personally, I like to spend the extra money on good LEDs from places like superbrightleds.com, because I've had issues with the cheap LED bulbs failing within weeks, and sometimes days. I'm thinking I'll probably just buy a bunch of bulbs from superbright, and try and offer the kit with the bulbs, but I may also sell a kit without the bulbs, that way some of you gamblers who want to roll the dice on the cheap ones can save a buck. Basically, I take the tail light bulb assemblies and add on the modules to them. The kit would come with modified bulb assemblies that you just swap out with the factory ones....Plug and play. Soooooo, I don't have pics and video of it yet, but hope to this weekend. Assuming they work and look good (I won't offer them if they don't), how many of you might be down for a sequential turn setup for $125-150 plus bulbs? Edited May 10, 2013 by Burton Quote Link to comment Share on other sites More sharing options...
BC_99 Posted April 24, 2013 Report Share Posted April 24, 2013 Yep. I'd want some. BC_99 Quote Link to comment Share on other sites More sharing options...
kidjc Posted April 25, 2013 Report Share Posted April 25, 2013 I'd... "2nd that notion"... Quote Link to comment Share on other sites More sharing options...
scott87star Posted April 25, 2013 Report Share Posted April 25, 2013 Sure Quote Link to comment Share on other sites More sharing options...
traps Posted April 25, 2013 Report Share Posted April 25, 2013 another Burton Mod to add to my list of wants. Quote Link to comment Share on other sites More sharing options...
taeisallin Posted May 5, 2013 Report Share Posted May 5, 2013 I'm down for a set Quote Link to comment Share on other sites More sharing options...
Walker Posted May 5, 2013 Report Share Posted May 5, 2013 i'm interested Quote Link to comment Share on other sites More sharing options...
RF600 Posted May 6, 2013 Report Share Posted May 6, 2013 Will that be all 3 bulbs working insead of just 2? If so I'm interested. I have sequential lights on my car now. They blink faster than I like. Do you know about how fast the blink rate will be? If it will be similar to the new mustangs, that's what I'm looking for. Quote Link to comment Share on other sites More sharing options...
Burton Posted May 8, 2013 Author Report Share Posted May 8, 2013 Will that be all 3 bulbs working insead of just 2? If so I'm interested. I have sequential lights on my car now. They blink faster than I like. Do you know about how fast the blink rate will be? If it will be similar to the new mustangs, that's what I'm looking for. Yep, all 3 bulbs will now be part of the turn signals. These involve getting new pigtails to replace the outer OEM pigtail (allowing outer bulb to be both park and brake/turn). It also requires the use of LED bulbs as stated above, and replacing the flasher unit with one that will run LEDs. My setup will come with the modules and new pigtails wired up. It will probably come with LED bulbs and the flasher unit too. It will be plug and play other than running a wire to the 3rd brake light wire at the base of the driver's side hatch strut (wire included). As with all my products, it will come with thurough installation instructions, with pictures. Here's a vid with the hazards and parking lights on, so you can get the feel of the blink rate, as well as see the brightness of the turns and the parking lights. These are using small, 9 LED bulbs from superbrightleds.com... https://www.facebook.com/photo.php?v=4447326196199&l=4601145448261514735 I'm still working on the pricing, but I'm probably gonna be in the $150 range with bulbs and a flasher. I'm also going to be working on a 3rd brake light flasher too in the upcoming weeks, and may add that to my kit too, down the road, but I suppose I could try and work that in sooner if there was interest... I figure that would probably add about $30. So, whatcha think? Quote Link to comment Share on other sites More sharing options...
Burton Posted May 8, 2013 Author Report Share Posted May 8, 2013 (edited) Oh, also, as of now, this would have to be a send-your-bulb-housings-for-me-to-mod sort of things, as I do not have very many spare bulb housings laying around.... I have 3 LH ones, but no RH ones. If anyone has any spare bulb housings they want to part with, especially RH ones, let me know. Edited May 8, 2013 by Burton Quote Link to comment Share on other sites More sharing options...
Fuze Posted May 8, 2013 Report Share Posted May 8, 2013 So, whatcha think? I think these are dope! Quote Link to comment Share on other sites More sharing options...
RF600 Posted May 10, 2013 Report Share Posted May 10, 2013 Can the lights blink slower? The ones I have now are close to yours. Can it be slowed to the rate of the newer Mustangs? Or slower than what you have? Quote Link to comment Share on other sites More sharing options...
Burton Posted May 10, 2013 Author Report Share Posted May 10, 2013 (edited) Can the lights blink slower? The ones I have now are close to yours. Can it be slowed to the rate of the newer Mustangs? Or slower than what you have? Nope. A couple other people brought up they'd like to see it slower. I spent 3 hours surfin the net, and can't find any modules that are adjustible, so this is it. If I was building my own modules, I could build them to a certain speed, but that's just way too much time for me to invest. I buy quality, pre-made modules that I wire in, and the pre-made units are not adjustible. Here's the pricing. I will offer these two ways..... With LED bulbs and a new LED flasher, and without Sequential setup #1- $120: This will come with LH and RH OEM bulb housings that have had the sequential modules wired in. The outer bulb 2 wire sockets are also replaced by new 3 wire ones. As with all my products, it will also come with detailed installation instructions. and any necessary hardware. You will have to provide your own LED bulbs and LED flash relay Sequential setup #2- $170: This will come with everything in Setup #1, but also comes with 6, 12 LED bulbs (the ones in the video above are 9 LED), as well as a turn signal flash relay designed to work with LED bulbs. I purchase this stuff thru superbrightleds.com, and while the quality of their products is top-notch, they are also more expensive than the cheap LED bulbs on the market. I've had horrible luck with cheap LED's so I will not use them in conjunction with any of my products. If my name is going to be on something, I want it to be of the highest quality possible. PLEASE NOTE!!!!!!!!!!! The sequential module is designed to run LED bulbs, The OEM style turn signal flash relay is not. If you do not replace the flash relay with one made to run LED's, the lights will not work. If you use standard bulbs instead of LEDs, your lights will not work. I currently have 2 LH and 2 RH bulb housings on site, and another one of each on the way, so for right now, I am only offering 3 sets. These will be built in order of purchase, and should take about 2 weeks from full payment to have ready to go. First come, first served;) Prices include shipping and Paypal fees. Paypal: markewade@gmail.com Prices also include a core charge for your old, un-modded bulb housings.... After installing your sequential bulb housings, you can send me your old housings and get $20 back. Thanks! Edited May 10, 2013 by Burton Quote Link to comment Share on other sites More sharing options...
BC_99 Posted May 10, 2013 Report Share Posted May 10, 2013 OK, just for clarification, they blink like that with brakes or turn signals or hazard lights? BC_99 Quote Link to comment Share on other sites More sharing options...
scott87star Posted May 10, 2013 Report Share Posted May 10, 2013 I'm in for the full monty, payment sent. Quote Link to comment Share on other sites More sharing options...
Burton Posted May 10, 2013 Author Report Share Posted May 10, 2013 (edited) Scott bought all the sets, and as of now, I will not be making more. Edited June 5, 2013 by Burton Quote Link to comment Share on other sites More sharing options...
JohnnyWadd Posted March 11, 2014 Report Share Posted March 11, 2014 cool Quote Link to comment Share on other sites More sharing options...
importwarrior Posted March 13, 2014 Report Share Posted March 13, 2014 missed out ... Quote Link to comment Share on other sites More sharing options...
MotoCam360 Posted March 13, 2014 Report Share Posted March 13, 2014 Our premium version LED Tail Light Conversion kit has sequential blink with user frequency control: http://www.themotocam.com/products/starquest?page=shop.product_details&flypage=ilvm_fly_showroom_mall.tpl&product_id=141&category_id=28 We need to update a few pictures for this listing this weekend tho Quote Link to comment Share on other sites More sharing options...
mechengrkj Posted March 14, 2014 Report Share Posted March 14, 2014 Our premium version LED Tail Light Conversion kit has sequential blink with user frequency control: http://www.themotoca...&category_id=28 We need to update a few pictures for this listing this weekend tho Have you considered doing a different shape of bulb for your lights? I'm not a fan of the round tail lights. Like maybe multiple lines of lights like these that D_Venable did? Quote Link to comment Share on other sites More sharing options...
Skrilla Posted March 14, 2014 Report Share Posted March 14, 2014 Have you considered doing a different shape of bulb for your lights? I'm not a fan of the round tail lights. Like maybe multiple lines of lights like these that D_Venable did? Yeah Id buy a set like that Quote Link to comment Share on other sites More sharing options...
MotoCam360 Posted March 14, 2014 Report Share Posted March 14, 2014 We would have to charge $1000 per set... cost prohibitive for almost everyone. Just ask D_venable how much his are worth Quote Link to comment Share on other sites More sharing options...
Burton Posted March 22, 2014 Author Report Share Posted March 22, 2014 Our premium version LED Tail Light Conversion kit has sequential blink with user frequency control: http://www.themotocam.com/products/starquest?page=shop.product_details&flypage=ilvm_fly_showroom_mall.tpl&product_id=141&category_id=28 We need to update a few pictures for this listing this weekend tho That's pretty classy of you to tout your items in another vendors thread. Maybe I'll come advertise some of my products on your posts For everyone else, I have found a supplier for better sequential modules. They are not adjustable, but the supplier can build them with a similar speed as the ones I posted before, or a slower speed. I will probably eventually offer and stock both speeds, but will start with the slower ones since those seemed to have the most interest. That said, I have a baby due a week from today and am slowing down my shop work for a couple months, but after that will be picking back up again. That's when I plan to start up the sequentials again. When I do, I'd like to get it going straight up without another GP, but that may change. If you can't wait, buy some from Motocam. I think he makes cool, quality products, even if he chooses to talk bad about me or my products and tries to advertise his products in my threads. 1 Quote Link to comment Share on other sites More sharing options...
JohnnyWadd Posted March 22, 2014 Report Share Posted March 22, 2014 (edited) Sequential module assembly 1 each. Ship to me please. Also I need mine to be speed sensitive so faster when leaving freeway off ramp at 90 mph, and slower when turning into my driveway. Thanks. Edited March 22, 2014 by JohnnyWadd Quote Link to comment Share on other sites More sharing options...
vbrad511 Posted March 22, 2014 Report Share Posted March 22, 2014 For $500 tails, they'd better change my oil, check tire pressure, and get a discount at the gas pump. Quote Link to comment Share on other sites More sharing options...
