StallionProject86 Posted August 10, 2011 Author Report Share Posted August 10, 2011 (edited) Update I've changed the pressure solenoid back to the oem one and the problem didn't change any. .so I'm going to have to say I have an injector issue. I'll be trying to get them flow tested and rebuilt this week to see if I make some progress. .Anyway I got a new part, Bc's radiator cover; thing is awesome I love carbon! http://i874.photobucket.com/albums/ab308/LAJits-media/The%2086/2011-08-09_12-23-50_725.jpg thanks again BC! Edited August 19, 2011 by StallionProject86 Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted September 13, 2011 Author Report Share Posted September 13, 2011 (edited) Update* Okay so no, injectors are now freshly rebuilt with no change in my cars behavior with the correct ecu installed. .now I'm still using the ecu that I initially thought was for an 87' (with further research it must be from an older 86 the label reads 0197 vs 1177 that came with the car.) because with it, it'll get me from point A to point B. Anyway I am going to perform a boost leak test on it today and we'll see what the results of that are. . P.s. new part, Auto Meter wideband and that will be going in as soon as I figure out a place to mount it.P.p.s. .working on getting an MPI set up. Edited September 13, 2011 by StallionProject86 Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted September 14, 2011 Author Report Share Posted September 14, 2011 (edited) Kay good and bad news. First off she passed the boost leak test with flying colors and I got my ecu to cooperate with the car..changed the spark plugs and wires as well as my translators setting. .now the bad part, I took for a swift drive and it starts bucking like a wild horse on me. Edited September 14, 2011 by StallionProject86 Quote Link to comment Share on other sites More sharing options...
Monk The Abbott Posted September 15, 2011 Report Share Posted September 15, 2011 Update I've changed the pressure solenoid back to the oem one and the problem didn't change any. .so I'm going to have to say I have an injector issue. I'll be trying to get them flow tested and rebuilt this week to see if I make some progress. .Anyway I got a new part, Bc's radiator cover; thing is awesome I love carbon! http://i874.photobucket.com/albums/ab308/LAJits-media/The%2086/2011-08-09_12-23-50_725.jpg thanks again BC!i want one what fuel pump are you running?clogged fuel line?....i just got mines running today....havent heard her roar in exactly 2 months...she died on me after mod....i had a bad injector...which was sending too much fuel....i still have a small fuel leak, Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted September 17, 2011 Author Report Share Posted September 17, 2011 Hit up BC mayne I believe he got a second run together. The fuel pump is stock to my knowledge, and ultimately I think that's the problem. .it's not sending enough fuel up. The reason why it actually runs with the 88-89 ecu in my opinion is because the ecu is sending the signal of a small primary running instead of the two 850's that the 86 computer calls for. .I'm going to have to check the fuel pressure but I think that is the problem. Hopefully she'll be 100% soon. I'm glad to see yours is back up Quote Link to comment Share on other sites More sharing options...
Komeuppance Posted September 17, 2011 Report Share Posted September 17, 2011 So, this is where your virtual mechanic thread is. LOL... how did it run before the MAF-T?? I see that you have a 16g @ 10psi, is the ECU modded with a FCD/zener diode?? Also, here's a repeat question you may have missed from last week, "what's the fuel psi when it's doing this??" -Robert Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted September 17, 2011 Author Report Share Posted September 17, 2011 (edited) Yea I guess it is lol. I just didnt want to start up a whole new one. .and no I have one just isnt connected yet. .Ive actually backed the knob off though it should be at around 8 now. Fuel pressure im not sure yet need to get a gauge. I'll update the thread when I check it though. P.s. before the Gm maf it ran the same. Edited September 18, 2011 by StallionProject86 Quote Link to comment Share on other sites More sharing options...
Komeuppance Posted September 18, 2011 Report Share Posted September 18, 2011 It's not connected but you backed the knob off?? So it is connected, but you have it set so it's "not doing anything"...?? How did it run before the MAF-T came near the car?? -Robert Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted September 18, 2011 Author Report Share Posted September 18, 2011 No the FCD is not connected yet I have a Mbc and that's been on the car for awhile now. .sorry for confusion. .before the MAF was installed it was just the same. The MAF and translator didn't change a thing. Quote Link to comment Share on other sites More sharing options...
Komeuppance Posted September 18, 2011 Report Share Posted September 18, 2011 So... you don't have an FCD mod, which means you are hitting fuel cut. -Robert Quote Link to comment Share on other sites More sharing options...
Technology Posted September 18, 2011 Report Share Posted September 18, 2011 and maybe something else is wrong like jet valves are broken. Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted September 18, 2011 Author Report Share Posted September 18, 2011 (edited) So... you don't have an FCD mod, which means you are hitting fuel cut. -Robert ...even though in the past it was boosting 10 psi over and over again? I didnt run into any problems before. .it seems like now i'm getting issues on start up (hesitant to start and when it does the idle is low, about 400) then after about a minute it raises to 900 and then theres the boost issue. .but I think its the fuel pump not up to pare..I will install the fcd though just to be sure.. Edited August 24, 2015 by StallionProject86 Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted September 18, 2011 Author Report Share Posted September 18, 2011 and maybe something else is wrong like jet valves are broken. To my knowledge the previous owner got the jve when they changed the head I have the receipt and if I recall it wasn't done very long ago Quote Link to comment Share on other sites More sharing options...
Komeuppance Posted September 18, 2011 Report Share Posted September 18, 2011 Ohm out your CTS. Do a TPS/ISC reset. You should have replaced your fuel pump before getting a MAF-T and bigger turbo... but you are likely hitting fuel cut. -Robert Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted September 21, 2011 Author Report Share Posted September 21, 2011 (edited) Spotted! http://i874.photobucket.com/albums/ab308/LAJits-media/The%2086/photobucket-4232-1316645610681.jpg Edited September 21, 2011 by StallionProject86 Quote Link to comment Share on other sites More sharing options...
Monk The Abbott Posted September 22, 2011 Report Share Posted September 22, 2011 nice. Quote Link to comment Share on other sites More sharing options...
mistapickles Posted September 22, 2011 Report Share Posted September 22, 2011 Spotted! %20http%3A//i874.photobucket.com/albums/ab308/LAJits-media/The%2086/photobucket-4232-1316645610681.jpgI know the guys that run KROPS.....where were you at when this picture was taken? Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted September 22, 2011 Author Report Share Posted September 22, 2011 Oh really. ? Thats cool. I was around just browsing the show. Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted September 29, 2011 Author Report Share Posted September 29, 2011 Alright so here's an update on the drive ability, changed out the fuel pump and installed an Hks fcd nothing changed. .even when adjusting the translator the af gauge stayed pegged at 16..anyway I unplugged the cts and started the car back up now its full on rich with the translator not doing a thing. So Im assuming the cts has been to blame all this time? I will ohm out both cts's I have tomorrow and see what I find. Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted September 30, 2011 Author Report Share Posted September 30, 2011 (edited) Well im using a 330 ohm resistor now in place of my of my cts and im still having problems. Really haulted over this could the problem be because I have a 3.5" versus a 3" like most cars are running here. ? I really dont want to sell the car but now my dads getting involved and throwing out the you need to sale it and move on bit. I really want to keep her though but im running low on options here. Edited September 30, 2011 by StallionProject86 Quote Link to comment Share on other sites More sharing options...
Komeuppance Posted September 30, 2011 Report Share Posted September 30, 2011 What should be done before modding is making the car run perfect. You don't need a MAF-T at 10psi on a 16g anyway. How was the car running on the stock turbo?? -Robert Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted October 1, 2011 Author Report Share Posted October 1, 2011 (edited) Stock was fine for awhile then after the turbo was blown I upped it to the 16g since I had to to replace it anyway. .after that while it was still running fine, the pressure solenoid broke and that's when it seemed to go down hill.. replaced it initially with an egr solenoid and it worked for awhile then slowly it started getting worse so I started changing what I read to cause the problems as well as replacing the solenoid with a known good oem solenoid and since I changed the maf I went with upgrading to future proof the car because I eventually wanted to get the gm maf and translator. ...So anyway I was working on the car and it seems like I'm finally making progress, I have the cts rigged up a little different and the car smoothed out... the thing now is getting it dialed in.. the hks fcd has a separate dial for tuning and when I mess with that I get very big jumps from lean to reach, seems very sensitive I also have everything plugged in map sensor, tps, o2 sensor. And on a side note I have an older fcd if that makes any difference the only thing that identifies it is the number on the back: FS26587 Edited October 26, 2011 by StallionProject86 Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted October 7, 2011 Author Report Share Posted October 7, 2011 (edited) http://i874.photobucket.com/albums/ab308/LAJits-media/The%2086/droidrevamped.jpg And as for her condition still very lean even with my Maf-t almost pegged to the rich end. .I'm assuming that my 3.5" maf is just to much for her so I have a 3" on it's way. Hopefully that will clear up the symptoms Edited February 17, 2012 by StallionProject86 Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted October 11, 2011 Author Report Share Posted October 11, 2011 (edited) WHY SO LEAN..? Got the 3" MAF on there now and still having problems with WOT & cruise, she leans out AFR reads 17.9 @WOT and around 15-15.4 at cruise..When I start the car after it cools, it's nice and rich 12-13 then shortly after it climbs to 15-15.2 of course it takes fuel away after it warms but why so much, what's going on here with cruise and wot? I have four sets of 850 injectors and they've all been tested and cleaned. I'm using the stock 850s right now as I've been told that they are 25% richer then the Delphis..but I'm still lean! My translator is set as follows: E,3,8,8 I can't turn the base any richer as it immediately dies. Any insight? Edited October 26, 2011 by StallionProject86 Quote Link to comment Share on other sites More sharing options...
StallionProject86 Posted October 26, 2011 Author Report Share Posted October 26, 2011 (edited) New set of pictures. . . http://i874.photobucket.com/albums/ab308/LAJits-media/The%2086/IMG_8355edit.jpg http://i874.photobucket.com/albums/ab308/LAJits-media/The%2086/IMG_8354edit.jpg . .Same ol' problem. Can't figure this lean thing out, where does my fuel go?? It seems like when I give the car gas it runs lean somewhere around 15.4 is what my wideband reads;yet when I let off the throttle I get about 13.2? Something up with my cable. ? Or is it something that reads positioning? I miss boost! Edited August 4, 2012 by StallionProject86 Quote Link to comment Share on other sites More sharing options...
